Question about Acer Computers & Internet
How do i change my fan on my acer 2500 - Acer Computers & Internet
Magiccc
Posted on Nov 11, 2009
I have a 06 2500 dodge sprinter and the fan control speed wheel isnt working. Settings 1-4 will not work. I can feel hot or cold air coming out of the vents while I'm driving but cannot adjust it.
I have changed the resistor 2 times for the same problem. Its under the hood behind the fan motor insulation.
Mine burned because of fan motor frozen & stuck in the winter. Solution is to let the engine warm up before turning the fan on.
Cheers, Brian
Jun 30, 2012 | 2006 Dodge Sprinter
My acer travelmate 2500 overheats when playing games
The cooling on the Acer Travelmate 2500 is worse than most because it contains thin copper heatsink fins which grab the dust as it flies past. Great for getting rid of heat; terrible for getting rid of dust.
prise off the two corner pieces that cover the hinge for the screen. Underneath there are two screws. Remove these, then peel away the keyboard and the plastic covering. There you will see the fan system. Four screws (on springs - careful) will have this away but be aware of the power cable which is tucked in behind a piece of metal. At all times be careful not to damage the keyboard ribbon cable which is usually pretty fragile.
Another few screws (tiny ones) will have the top of the fan off then you can clean and put it all back together. The result: a laptop that actually blows air through and cools what it should.
Kindly rate if this helped Regards
May 13, 2011 | Acer TravelMate 2500 Notebook
94 ram 2500 temp fluxuates from 170 to 220 degrees but never goes over 220 changed thermostat but no difference no leaks
possible fan clutch issue with vechicle at operating temp shut off truck see if fan spins freely if so its bad should only make 1or 2 revolutions when spun by hand
Feb 09, 2011 | 1994 Dodge Ram 2500
Acer Travelmate 2500: Where's the wireless card fitted?
go to http://tim.idau/laptops download your service manual it will show where wireless card & bluetooth card are installed, good luck .
Jan 04, 2010 | Acer TravelMate 2500 Notebook
Upgraded Acer 2500 Travelmate with a Wireless card
you can find the driver from here. download and install to use Wi fi
http://support.acer-euro.com/drivers/notebook/tm_2000.html
May 30, 2009 | Acer TravelMate 2500 Notebook
How do i update bios on an acer travelmate 2500 - downloaded bios update onto another pc as i can't install xp due to acpi etc blue screen?
Scroll to the bottom and you will find the download for the update.
P.S. DON'T FORGET TO VOTE!
Apr 16, 2009 | Acer TravelMate 2500 Notebook
99 Dodge Ram 2500 won't heat up
Is the engine fan staying engaged? If so this will not allow you to build addequate engine temp. especially while driving.
Jan 09, 2009 | 1999 Dodge Ram 2500 4WD
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
