Question about iLO DVDR05 DVD Recorder
Parental control I can't find the manual. I have never set a password for parental control. Is there a default password? Thanks!
  • Anonymous Mar 25, 2014
    How to change parental password
THe default for our ilo dvd recorder was 1369 - not sure wat model it was - mayb its the same for them all?
Posted on Feb 19, 2007
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Tip
Mintek DVD Player Password for Parental Control
If you have lost or cannot remember the password for your Mintek DVD player the default parental password for these units is 8 8 8 8 8<br /> <br /> This is the factory default password and can be used to reactivate the unit when it is showing parental lock.<br /> <br /> If you found this Tip useful please do leave a vote for it.<br /> <br /> Thanks for using FixYa.
on Nov 17, 2010 | Televison & Video
Parental control password?
Try to downlaod the user manual to your player from net. it will have all details.
May 02, 2012 | Televison & Video
How to use parental control
You can enable customize Parental Controls via your TV's on screen menu. If you have previously set a password, you will need to re-enter your password to begin. If you have forgotten your password, try 0000 (four zeros) or 3448 (the default password may vary by TV model, so consult your User Manual for details). You can find detailed instructions for using the parental controls in your TV User Manual, available for download at InsigniaProducts.com. Just search for your TV model number and click on the Support/Download tab. I hope this helps.
Nov 23, 2011 | Insignia Televison & Video
My dad forgot the password on parental controls for xbox 360 thanks to him i cant accept friend requests which sux
Go to "Settings" and highlight the "Parental Control" option. Then, press X, Y, L, X at the passcode screen to reset the parental control setting to the default value.
Jan 13, 2010 | Microsoft Xbox 360 Console
Phase linear uv8= parental control problem
Is setup for default read the manual to get the password.
Mar 25, 2009 | Car Audio & Video
What is the v-chip code for polaroid tv
Parental
DVD discs equipped with the child lock function are rated according to their contents and settings vary from disc to disc. Depending on the disc, you can lock out selected scenes or playback of the disc altogether. Access parental control by pressing the left/right (direction buttons together) on the remote control and then press the OK button.
System Setup/Password
Parental control features are password protected. The original setting is unlocked. This setting allows you to use number buttons to input any password. Note: The Default Password is 1369. This password is always effective even after you
have selected your own password and changed it. To avoid the possibility of others using the default password to set the parental level and change the password, you can record this default password in another area and delete it from this manual. Some discs can be limited depending on the age of users while some discs cannot.
Manual is here
http://www.polaroid.com/service/userguides/ce/under_cabinet_lcd_tvs/fdm0700a_ug.pdf
(you need Adobe Reader) and their phone # is
at the end!
Jan 05, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Forgot V chip password on Insignia IS-TVDVD20A
i have an insignia hdtv and the manual says if you forgot the password, enter in 3448 in the password box to reset, it might be the same for yours, good luck
Jan 04, 2009 | Insignia IS 20" TV040919 TV
Need to change the parental control password
press select on your controller and then enter password 7444 this will delete current password and allow you to set a new one...
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Feb 16, 2008 | Cyberhome CH-DVD 300 DVD Player
iLO DVDR05 DVD Recorder Logo
69 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
