Question about Epson Expression 1680 Professional Flatbed Scanner
Lines through negative scans
I am using an Epson 1680 Professional scanner to scan black/white, 35mm negatives using the negative holder that came with the scanner. The negative holder holds four negative strips. Three of the four strips produce good results but the fourth row scans two lines across each image. I can actually see the lines during the preview.
Robert Kenkel
  • Anonymous Mar 18, 2014
    Hi all, i seem to have developed a fault with my epson V50 as it leaves 1 yellow line across the scans of negatives, sometime a blue one also.any idea how to fix it?
  • 490 Answers
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Posted on Dec 16, 2008
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
Scanning 35mm negs on my Epson Stylus PHOTO RX620
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
Aug 28, 2009 | Epson Perfection 4490 Office Flatbed...
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Epson V100 Document Mat error
Please check if the option cable connected on the back of the scanner is seated properly.
If you are using epson scan to scan from your computer, try to scan using either professional or home mode and choose the correct settings.
May 03, 2009 | Office Equipment & Supplies
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Splitting image
Are you using the epson scan software or something else? If you are using epsons software, it might be that the picture has verticl lines that the software is mistaking for different frames on your negative. Switch the software to professional mode. I go another step and use Vuescan, it's a better application in my opinion.
Sep 12, 2008 | Epson Perfection 4870 PRO Flatbed Scanner
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Epson Expression 1680 Professional Flatbed Scanner Logo
309 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
