Question about Coby MPC-848 MP3 Player
It won't turn on
Every time I try to turn on my mp3 player it just says Coby then shuts of and just repeats itself until I take out the battery. I even tried to put new batteries in but it just does the same thing. And I don't have the receipt because my friend gave it to me for Christmas.
  • 1 more comment
  • vkeller08999 Jul 28, 2008
    I have a mpc854 sony my computer states it has malfuctioned. I think I need to update the firmware, but I am having problems finding the website to do so.
  • hazleyez_c_u Aug 24, 2008
    i'm having difficulty turning mine on? it will not come on, weve changed the battery and still nothing?
  • majominu Sep 04, 2008
    Every time I try to turn on my mp3 player it just says Coby then shuts of and just repeats itself until I take out the battery. I even tried to put new batteries in but it just does the same thing. And I don't have the receipt because my friend gave it to me for my birthday.
I had this problem. I downloaded the firmware update/upgrade, and ran the executable file. Turned off the player, held down the pause play button while plugging into the USB port. The drive seem to have reset itself and installed a generic driver. DO NOT!!! Turn drive back on. You should be able to see drive in my computer now. Then run the firmware upgrade, you should choose the option to format drive. Copied a file and played it. Used the safely remove hardware option and was able to turn on MP3 player and operate with no problem. Note: update was an older version, probably the original driver, but it works.
Posted on Jun 20, 2007
A cold solder joint is the result of the solder not getting hot enough to completely liquify and bond to the pin and device. This can also be caused by "dirty" pins or device leads.
Posted on Jun 14, 2007
What the heck is a cold solder!!!!!
  • 4 Answers
I have the same player with the same problem. I partially fixed my player by re-soldering the positive battery terminal. Turns out there was a cold solder joint there. I suspect that there is at least one more cold joint so I'm going to take another look at it to see if I can "fix" it once and for all.
Posted on Mar 03, 2007
  • Corey Hudson Mar 03, 2007
    This is a follow up to my previous comment. There were multiple cold solder joints in the player. I re-soldered them all and now the player works just fine.
My coby 705 is very fast to low battery what even if it is fully charge, what should i do?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 09, 2011 | Coby MP-705 Digital Media Player
Have a Coby MP-C7085 that will not turn off. What
Hello :
First you need to wait until the battery is empty to let it shut off .
then you need to replace your mp3 player battery with a new one . When battery life is ended , it can't be recharged anymore .
good luck .
rate please !
Mar 19, 2010 | Coby MP-C7085 MP3 Player
I have a coby 256 MB MP3 player and whne turned on it just says COBY and shuts off. BAtteries are new
try reseting the device its usualy a small pinhole on the back or side of the device try holding that in for about 10 seconds
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
Sep 28, 2009 | Coby MPC-848 MP3 Player
My mp3 player wont come on
did you try holding the button? thats how mine works
Nov 30, 2008 | Coby MPC-848 MP3 Player
Only say coby and turn off
resolding point of battery...
Sep 04, 2008 | Coby MPC-848 MP3 Player
Coby MP-C7085 Wont work
These players are plagued with problems! I have the 2gb version which does the same thing. I gave up on trying to use its internal battery and bought a usb charging cord for use in my car. I just unplug the cord from the cig lighter socket when I'm done using it. If it doesn't shut off,which is 99.9 percent of the time, then it just runs its battery down until it finally shuts off. It's a shame this player doesn't work as good as it looks...
Mar 18, 2008 | Coby MP-C7085 MP3 Player
My coby mp-c7092 will not turn on
Make sure you have a good battery in it...check the back to see if the hold switch is on or off, and of course hold the power button until the screen lights up.
Jan 11, 2008 | Coby MP-C781 MP3 Player
My mp3 player wont turn on
I have an identical problem with my mp3 player which looks similar but isn't the same model. There's something up with the play button, some moisture or grit or dust has got underneath the contact for the play button so that the mp3 player thinks you are constantly pressing the on/play button.
Put it in a warm dry place. I have had this problem twice & this has fixed the problem on both occassions. If there's more than moisture trapped inside, that can be harder to shift. But there are no moving parts in this player so don't be afraid to give it a good shake to try & get things moving.
Jan 07, 2008 | Coby MPC-848 MP3 Player
Coby mp-c848
Your batteries may be dead, the coil that it (the battery) attaches to sometimes gets bent out of the way, so try turning that back.
Oct 25, 2007 | Coby MPC-848 MP3 Player
Coby MP-C848 MP3 Player
how do i get music on to my coby mp3 from the computer, my daughters works from the computer why doesnt mine
Jan 01, 2007 | Coby MPC-848 MP3 Player
Coby MPC-848 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
