Question about Sony DVP-CX875P DVD Player
Sony DVP-CX875P Remote Control sensor problem.
After transporting this unit with DVDs still in place, remote control operation resulted in the unit's door simply opening whenever play was selected on the remote. This was caused by jammed DVDs in the carousel. The cover was removed as well as all DVDs. Now the remote will not work. Could not find any loose wires in the changer. The infrared sensor appears to be physically located on one of the pc boards at the front of the unit.The remote control unit has new batteries, and a test of the infrared emitters indicates they are also working. Any ideas?
    Habit-Forming:
  • 53 Answers
It could be that the remote is sending mixed signals if multiple buttons were accidently pressed at the same time. You can reboot the remote by removing the batteries, then while they are out, pressing all of the buttons on the front of the remote. This discharges the circuit board in the remote. Put the batteries back in and try it again.
Also, in case you don't have it, here is a link to the manual for that unit:
https://docs.sony.com/release//DVPCX875P.pdf
Posted on May 03, 2017
hughv
  • 196 Answers
SOURCE: jammed sony dvd
Unplug the power cord for at least 30 seconds, then try again.
Posted on Jun 10, 2007
  • 3 Answers
SOURCE: DVP-S560D will not play some dvds, C:13:00 flashes at bottom of screen
Try using a Laser Lens Cleaner disc - get the "wet" type that uses fluid. Target stores carry an inexpensive one.
Posted on Jun 01, 2008
  • 130 Answers
SOURCE: Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Posted on Apr 15, 2009
SOURCE: New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Posted on Jun 23, 2009
brownline45
  • 310 Answers
SOURCE: Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Posted on Jun 19, 2010
Lost remote what is univesal remote code in order to control with other remote
Why don't you just order a replacement remote? The model number for remote that is compatible for the DVP-F21 is the Sony RMT-D137A. You can find a replacement remote using the http://EzRemoteFinder.com website. This website will search many remote control vendors for the lowest price remote. Here is a link to a list of results using the Sony RMT-D137A remote model#:
Looking for that lost remote control
Best of luck to you!
Mar 29, 2016 | Sony DVP-F21 DVD Player
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
Sep 18, 2014 | JVC Remote Control RM-STHD5J p/n:RMSTHD5J
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
I purchased dvds from ebay and they will not play on my dvd player. Is there a way i can unlock or change the region on my Sony DVP-SR200P DVD Player? Please help!!!
Or
Or
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Apr 14, 2010 | Sony DVP-SR200P DVD Player
SOny DVD Player DVP-NS50P Locked
press stand by and press return button and enter button and then press stand by button on ur remote control.the player will be unlocked
Dec 27, 2009 | Sony DVP-NS50P DVD Player
I have lost my remote controll. How can I replace it??
The link below contains the original replacement remote control for your unit.
Sony DVPNS575P Replacement Remote Control
Dec 10, 2009 | Sony DVP-NS575P DVD Player
Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
Nov 22, 2008 | Philips DVP 720SA DVD Player
Sony DVP-CX875P  DVD Player Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
