Question about Compaq Presario 2598Us Notebook
Wi-fi WPA2 Support?
I can't connect to a Versalink 327W router with WPA2 encryption. WPA-PSK works fine. Does anyone have a clue why? The wireless card on my laptop is Broadcom 802.11b/g WLAN which uses the BCM94309 chip.
    Scholar:
  • 118 Answers
Try doing the following:
1.) Go to Start -> Control Panel -> Performance and Maintenance -> Administrative Tools -> Services.
2.) Scroll down to Wireless Zero Configuration, and double-click Wireless Zero Configuration.
3.) On the General tab, after Startup type, change the startup type to Automatic.
4.) Start the service by clicking Start.
Let us know if this works, and good luck!
Posted on Dec 03, 2008
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Wi-fi pasword connot conect to wi-fi
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Dec 18, 2012 | Samsung Corby 2 GT S3850
Cant figure tha wpa - psk/ wpa2- psk number to connect my playstion
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the Playstation, laptops and orcomputers with these router's wireless settings. Then the playstation, laptops and desktopcomputers can communicate with your wireless router.
May 15, 2011 | Computers & Internet
I click on WLAN, then set up wizard. It serched SSID and found the house ID which I click. then it comes up with options: open system, shared key and WPA/WPA2-PSK NO CLUE WHAT ALL THESE MEANS.
Theencryption key secures your data from unauthorized access. Your wireless router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 25, 2011 | Brother MFC 6490CW InkJet Printer
How do I connect my iphone to my wifi in my home? I have a belkin wireless router
You will need to know what encryption method is being used. Assuming you are using 802.11(a/b/g/n) it will be WEP, or WPA / WPA2 with a preshared KEY (PSK) or TKIP.
If it is WEP, you will need to copy the entire key from your router's wireless configuration page. Then on your iPhone, click Settings, Wi-Fi then select your network and enter the WEP key.
If you are using WPA or WPA2 with a pre-shared key, select that option and enter your key and it should connect immediately.
If your network is not being broadcast then you will need to manually enter the settings under Settings, Wi-Fi, Other.
Apr 13, 2011 | Computers & Internet
What is the wep password
The encryption key secures your data from unauthorized access.
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 30, 2011 | Linksys PAP2T
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do make my router secure when its states it unsecure
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Compaq Presario 2598Us Notebook Logo
388 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
