Question about Western Digital My Book World Edition 1TB Remote Access Storage System
Can't access My World Book 1TB through my browser.
I hope someone can help since WD can't. I have a 1TB My World Book drive and cannot acess it through my browser. Typing "mybookworld" in my browser has never worked. I ended up assigning it a fixed IP on my network to get it to even work. Now, I can access Shared Storage Manager through my browser by typing the IP address, but once I try to click on a different area, it says I haven't authorized correctly and to check the manual. Of course, this isn't mentioned in the manual. A pop up window asking for a username/password used to come up, but it doesn't anymore. Pop up blocker is off. Any help?
  • deepsgrrl Dec 10, 2008
    I have the exact same problem and i am sick to my stomach about all my pictures gone!
    Now WD wants me to send this drive off to an outside source to get the information off. Costing me $500 to $2500!!
    HELP!
  • ashleybust Feb 09, 2009
    i have the same thing going on with my world book but mine is the 2tb any help on this one??
Hi Vonnossa
I had exactly the same issue after removing the MioNet software. My device is connected to a router that assigns IP addresses (DHCP) and can easily be accessed using explorer and by mapping the drive so that its available on startup.
The solution I found is as follows.
The unit has a default reset button that will reset the unit User Name to "admin" and the Password to "123456" Without the quotation marks.
The button is recessed in a small hole between the power connector and the network connector on the back of the unit. Its much the same as the small hole on a CD/DVD Drive used to remove discs from a PC that is switched off. You will need a paper clip or similar to reset the device.
Step 1. Switch off the unit and remove all leads.
Step 2. Insert the paper clip into the small hole mentioned above and press (not to hard though)
Step 3. With the clip still in the hole, connect the power lead and switch the unit on.
Step 4. Wait until the circular power button lights up ( this can take anything up to a couple of minutes). Once lit count to 10 and remove the clip.
Step 5. Re-connect the network cable and return to your PC.
Step 6. In your browser type in "wdstorage" No quotation marks.
Step 7. This will open the shared storage manager page. select your option and when it prompts for username enter "admin" and for password enter 123456
Once done you can change usernames and passwords as required.
Good luck
Dave
Posted on Dec 29, 2008
I have a WD 1tb My Book and it stopped being recognized
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 28, 2010 | Western Digital MY BOOK HOME 1TB EXT...
Western Digital World Book 1TB - Lights don't light, HDD vibrates
I would try to connect the drive directly into an ide or a sata cable on the motherboard. Maybe using the western digital tools from their website you'll be able to access the data and copy it. I hope this helps you.
Aug 23, 2009 | Western Digital My Book World Edition 1TB...
Can't Access my WD World Book.
what system you use for your WD World Book
Jun 17, 2009 | Western Digital 500GB My Book World...
I can't access my drive through mionet. My son accidently unplugged the world book and I can't access it ever since. Should I reinstall the mionet. I can't remember if there were any installation CD that...
Once the My Book World has been plugged back in, it will request a new IP from the Router. If the drive was unplugged accidentally, the ethernet cable may have also been knocked loose: make sure all cables are attached to the Router and the My Book World.
If your drive is still not appearing properly in MioNet, you can do a Hardware and Software reset on the drive. It will not affect your data, and it will allow you to re-attach the drive to your MioNet account. You do not need to reinstall MioNet to do this.\
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
You should now be able to sign in to the Shared Storage Manager as admin/123456.
5. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear.
6. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup" then choose "WD Anywhere Access settings." Use the default username of "admin" and default password of "123456" (without the quotes). On the following page you will have three buttons to select, please click on the "Reset" button. This will return the MioNet software on My Book World to default settings.
7. From within the MioNet Client, go to File > Remove Computer. Locate the My Book World (WDStorage, MyBookWorld, or whatever you named it) and remove it.
8. If you do not see a new window from MioNet informing you that you have a storage device available, "Scan for Cameras and New Devices…" to detect the unit.
Jun 11, 2009 | Western Digital My Book World Edition 1TB...
Wd my book world 1tb will not power up
check usb interface. problem in usb terminal. try to press round button switch.
Jun 01, 2009 | Western Digital My Book World Edition 1TB...
Web browser security won't let me access my world book
change the security level to low, it will allow you to access your desired site.
Feb 23, 2009 | Western Digital My Book World Edition 1TB...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
Mionet application doesn't show files in subfolders of shared folders
I believe you have a choice of using either the web interface or the desktop version of Mionet when you are on the same network (LAN), and as you mentioned both of you have no problem when you are on the same network as the NAS drive (MBWE) is.
When you are out of the local network where your NAS drive is, the only choice you would have is the web interface of Mionet. Eventhough you may have installed the desktop version of Mionet tool on a remote PC, I don't think you can access through that desktop tool. Sorry !!!
Oct 30, 2008 | Western Digital My Book World Edition 1TB...
WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Oct 16, 2008 | Western Digital 500GB My Book World...
Next day WD World Book can not be accessed from IE
Look there for a start
http://mybookworld.wikidot.com/start
J.
Oct 01, 2008 | Western Digital 500GB My Book World...
Western Digital My Book World Edition 1TB Remote Access Storage System Logo
14,172 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
