Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
No Power Was working, and then power shut off
    Problem Solver:
  • 7 Answers
If this vacume get stopped up the motor will heat up and shut down try and see if the hoses underneith and back are clean and open and also make sure all 3 filters are either new or clean. that should help it form shutting down
Posted on Dec 30, 2008
Motor does not shut off
You can change the switch.
Jan 16, 2016 | Vacuums
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Vacuum works but won't shut off
Switch is broken in the "ON" position. Just plug it into a power strip outlet and use the switch on the power strip outlet to turn it on and off.
Nov 08, 2015 | Vacuums
No power shut off while running.
Could you please rephrase your question. I don't understand it. If you mean that the vacuum won't shut off, just pull the plug. Joking. It's in the switch, that will have to be checked, cleaned and maybe replaced.
Oct 15, 2013 | Dirt Devil Vacuums
Our Electrolux canister vacuum just stopped working when we were vacuuming the floor. The power does come on when the power head is attached but as soon as the power head is removed the power shuts off. I...
The guardian is the most complex vacuum I've ever worked on. The technology exceeds all others. Usually the problem is with the computer board in the handle. My suggestion is to take it to the nearest Aerus Electrolux dealer. http://www.aerushome.com/storelocator/
Dec 31, 2009 | Electrolux Guardian Bagged Canister Vacuum
Power nozzle suddenly stopped working (no power or vibrating). Can these be repaired or should I just buy a new one?
Hello. Check out your reset button located on the top of the power nozzle. It is either black or red. Turn the cleaner on, and while running, push in the reset. Voila! It should be working again. The reset is put in the vac to protect your power nozzle motor. You have a geared belt that is driven by a circuit breaker protected motor. This way, if there is an overload on it, it will shut off, allowing you to clear it and reset it. I hope this helps! Have a good day.
Nov 05, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have a red c velvet. My vacuum keeps shutting
Could be you have a filter issue and it is overheating and shutting itself off. Make sure you have not put on the wrong filter type for the machine. Some of the pieces that come in the FJM boxes are not actually filters and people make the mistake of putting them on as filters. The other major problem that could be happening is that there is some problem with the hose itself. On my vacuum it will shut itself off after 2-5 minutes, but the power light remains on. I have to press the up button to get more suction, but that only lasts until it shuts itself off again. If I unplug the hose from the cannister... the power comes on fully and the vac never shuts itself off.
A tech told me that the likelihood is that there is some component or connection in the hose control that is causing faulty shutdown. He told me I would need a new hose costing $175. After a year of trying different things, I am convinced he is right and we need to bite it and just buy a new hose.
Sep 13, 2009 | Miele S558 Red Velvet Bagged Canister...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
231 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
