Question about Brother ULT2001
Needle hits presser foot
I have a 10 year old Kenmore sewing machine. I was sewing the other day and the needle hit the presser foor and bent. Now the needle will not hit the opening in the presser foot at all. It hits about 1/32 inch to the right of the hole. I dont' have the money to get it professionally repaired right now. Is this something I can fix myself?
MakikiChris
  • 84 Answers
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
Posted on Aug 02, 2007
SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
  • 323 Answers
SOURCE: bobbin thread wont pick up
Be sure needle is inserted correctly with the flat side in the proper position. Rethread the machine and try again. If it still won't work you have a timing problem which requires a technician or a good mechanic.
sewman7
Posted on May 19, 2008
  • 3 Answers
SOURCE: I have a Euro-Pro 473 model sewing machine, I?m
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
Posted on Oct 01, 2009
SOURCE: white d'lite 1750c presser foot in down position not recognized
This also happens when the bobbin winder is too close to the right-like when you wind a bobbin and don't put it back or not back all the way to the left.
Posted on Nov 23, 2009
My elna experience 660 is bunching threads in big loops on the back of the fabric and the needle bent and hit the needle plate. It's sounding clunky
Install a brand new needle.
Remove the top thread from the machine (ALWAYS cut the thread at the spool, raise the presser foot, and pull the thread down through the needle eye.)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still does not sew properly or sounds clunky, take it for service. It could have been knocked out of time or bent something.
Jul 01, 2017 | Elna Sewing Machines
My needle keeps hitting the presser foot. I cannot see any adjustments to make. I have taken everything off and re tightened.
make sure that you have the right for installed for the sewing pattern involved
the straight sew foot will have a hole that the needle works through but if you have it on button hole , zigzag or any other pattern that moves the needle sideways then the fot will be slotted
check for bent needle or thread tension excessive and pulling the needle sideways on the down stroke
Sep 19, 2016 | Sewing Machines
Replaced broken needle clamp, but presser foot blocks needle shaft from going all the way up & the drive wheel cannot complete a turn to pull thread.
I'd need to know what type of machine you have, but maybe you aren't putting the clamp on correctly. They are fussy! Be sure you have the flat side of the needle facing the correct way and that you wiggle and jiggle it while pushing up on the needle. Also, make sure you are using a new needle and not the old bent one. Sometimes the clamp will come in 2 pieces, so it may not have broken, just came undone.
Dec 30, 2015 | Sewing Machines
Feed dogs are hitting the needle plate
Needle is bent replace with new needle. You may need to adjust feed speed so that needle doesn't bend. Good luck
Jun 06, 2015 | Sewing Machines
Needle hitting pressor foot
Presser foot not correctly mounted, or needle bent, or needle bar loose or bent are the most likely.
Mar 18, 2014 | Kenmore Sewing Machines
Needle is hitting presser foot and the plate beneath - not lining up and I can't figure out how to do it.
Your needle is incorrectly inserted or bent. Try a new needle and use handwheel to see if it is lining correctly. Flat part of needle should face the back of the needle holder and be pushed well in.
Dec 19, 2010 | Kenmore 19233 Computerized Sewing Machine
My kenmore sewing machine needle is coming down on presser foot.
Check the needle to make sure it is inserted with the flat side of the shaft toward the back of the machine.
Also, check to be sure the needle is not bent.
Remove the presser foot and see if the needle clears the opening in the needle plate and pulls up the bobbin thread.
If all of the above checks out, switch to a presser foot with a wider opening.
If not, the machine needs to be serviced as it may be the timing has to be adjusted.
Whenever you pick up a machine that has been serviced, try it out before taking it home.
Mar 17, 2010 | Sewing Machines
I have a problem with the needle shaft. It seems to be overextended by about 1/8" to the front of the machine. My needle is hitting the forward part of the presser foot.
Remove the foot - does the needle hit the needle plate?
Is the needle bent?
If the answer is no to both questions, it could be the machine needs to be taken in for repairs.
Feb 24, 2010 | Brother CS-6000
Needle move up and down slowly and hits the presser foot
when needles hit the presser foot they are out of alignment and the needles get bent
Nov 19, 2009 | Kenmore 19110 Computerized Sewing Machine
Sewing Machines Logo
308 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
