Heater does not start
I have a Lennox air handler and the heater does not work I try the thermostat voltage reading and they were okay when I switch to heaqter the unit starts but but no hot air, is there any reset in does unit since they don't work since I change the thermostat.
  • 1 more comment
  • luvil Nov 28, 2008
    I have a blower but I will check again the thermostat wiring to make sure is okay
  • cotillionsor May 11, 2010
    all systems have a blower. Does it use gas to heat or only electricity?the wiring is totally different depending on which it is.
    sounds like you may have wired the tstat wrong is this a heatpump or gas furnace. assuming heatpump by you stating airhandler instead of furnace you need to verify wiring at tstat and some you even need to go into the installers menu to tell it if it controlling a hp or gas furnace. please let me know how you have the tstat wied and type of system and i can help further.
There was a problem with the thermostat wiring like you suggest and it work. Thank you for your input and I will recommend this site to all my friends in case they need some help. Your response was fast too specially being a holiday weekend. Thank you again.
Posted on Nov 30, 2008
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Lennox Elite air handler will run cold for a while, then it will blow warm air out until the safety switch is moved, then it will make a noise in the system which sounds like air hissing, then the cold air...
sounds like installer broke on yellow wire between thermostat and condenser. your switch is breaking the 24 volt signal to cobdensor when the internal float is activated. moving the switch is somehow allowing bobber to drop enough to reactivate 24 volt and condenser comes back on. refrigerant starts to recirculate again and thats what your hearing in the lines. the switch prevents evap coil pan from spilling over into your return when the drain is clogged. use a shop vac and clear your drain. i blow it out with compressed nitrigen. after line is clear prime it wuth 32 oz of water.
Aug 07, 2013 | Heating & Cooling
I have a good heatpump with goodman air handler. the air handler has a sequencer and a blower relay. the blower relay quit working and i replaced it with a supco 90340 relay. the problem now is in the...
Your green wire from the tstat and the low voltage common should land on the relay coil. Your high voltage for the blower lands on normally open. Sounds like you are using your red (constant 24v) to energize your relay. Therefore your relay is constantly energized and your blower runs constantly. Let me know!!
Jul 01, 2017 | Honeywell Programmable Thermostat Heater
I have the T8775 model and the display went blank last night. Now the A/C is not coming on. Any suggestions on what I can do to fix it or what happened to it?
It is possible the batteries are dead in the t-stat.
If batteries are good check the power to the air handler.
If power is good the air handler transformer may be bad.(high voltage in and low voltage out)
If transformer is good check all low voltage thermostat wires especially red and blue.
Aug 02, 2011 | Honeywell Programmable Thermostat Heater
I have a Lennox A/C and air handler with a honeywell thermostat and the purge light is blinking. What can I do? I am not getting cold air.
check with thermostat commands from indoor to outdoor.May be your outdoor unit doesn't have command to operate.
Jul 24, 2010 | Amana PTH123B35AE Air Conditioner
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
Jul 06, 2010 | Heating & Cooling
Changed batterys in the tstat now air handle will not run
Turn the Fan switch to On, if the fan does not run,
either the thermostat is not telling it to run or you have blown a mini fuse in the air handler, assuming
you have no readout at thermostat.
disconnect thermostat wires and try to Jumper between R and W or W1. Remember to shut power
off before you start. If the air handler starts the
problem is either ther thermostat or thermostat wire.
Jan 11, 2010 | Heating & Cooling
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Lennox CB26UH Air Handler stopped running
Do you mean the air handler fan doesn't run but the outside part runs? If that is the problem, try turning the fan blade with a stick. If it turns freely, you have an electrical problem. It could be a relay, a bad motor winding, a bad capacitor, or a bad thermostat, among other things. If the fan won't turn, the motor needs to be replaced.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
