Question about Amana DLE330RAW Electric Dryer
Dle330raw amana stopped working
It stopped working all togther.i replaced the timer and still nothing.i jumped the door button still nothing the timer isnt even sounding like its working.ihave checked the power it seams to be gettin power.would the thermal fuse cause it not to run at all?
    Sergeant:
    Champion:
  • 311 Answers
Yes it would. Find it and jump it out to see. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
My amana dryer stopped working in the middle of drying and when i press the start button to come back on it makes a buzzing sound what could it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | Amana DLE330RAW Electric Dryer
The dryer drys but the dial does not move and....
HI. the timer control module is experiencing difficulties. the advancement of the timer dial is crucial, and it must rotate in order to initiate proper cycle sequence. The timer motor is the culprit in this case, and the timer will need to be replaced.
Replacing the timer will fix this issue.
Sep 09, 2009 | Amana DLE330RAW Electric Dryer
I have a Amana DLE330RAW everything works, but it won't heat?
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
Won't turn on
First check voltage and breaker,(this is a big one)
next, if you have power to the appliance (120 gas dryer or 240 electric) then the door switch is probaly broken.
lastly, perhaps a thermal fuse located on blower vent. goodluck
Dec 17, 2007 | Amana DLE330RAW Electric Dryer
Dryer
Tiff...there is a switch which indicates that the door is open. Most units require that you push the start button on the timer panel to start/restart. You must have time set on the timer to direct the dryer to work.
Nov 12, 2007 | Amana DLE330RAW Electric Dryer
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Oct 18, 2007 | Amana DLE330RAW Electric Dryer
Amana dryer ple330RAW
look for something stuck in the impeller (blower fan) that would cause the motor to hum and not run. If nothing is stuck your motor may be shot.
Aug 15, 2007 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
80 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
