Question about Philips Magnavox 27MS343S 27" TV
Tv will not turn on
Model # 27MS4504/17. while watching the tv, it just turned off and will not come back on. Cable is fine because we hooked another tv to it.
  • puddleglum59 Jan 17, 2009
    I was watching TV, and it turned off by itself. It will not come back on.
  • 67 Answers
A: Is there a humming sound coming from the TV set?
Check the brightness/contrast. If nothing still, remove power to the set for 24 hrs. and reconnect and retry. If it's not coming back up, the PCB ("motherboard") for the set has most likely died. Check for warranty information in your user's manual for further instructions.
B: Is the TV sharing an electrical line with a wall switch?
Remove the set from that circuit and try another outlet. If not, follow the Steps for "A".
C: Was it during a power storm, when it went blank?
Check the outlet with another appliance - if that device works, try the Steps in "A".
Posted on Nov 29, 2008
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
Tv turns off while watching it stays off a couple
Sharp 60" DLP 1080i , while watching cable, the show blinks off and on. but if we play video games or watch DVD's it works fine. what is wrong?
Jun 23, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Headphones
Most TV's do not have a "headphone" jack (defined as a 3.5mm headphone jack). You might need to connect the tv's audio out RCA jacks (the red and white ones) to a converter cable similar to one found here. However, some tv's don't have an audio out. Reply back with your tv's model number, and maybe I can give further assistance.
Steven
Sep 16, 2008 | Televison & Video
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Philips Magnavox 27MS343S 27" TV Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
