Question about Simplicity Denim Star SW210
Only sewing 1 side of the zig-zag
I am trying to sew with a stitch width of 3. The needle goes down fine on the left, then when it goes down on the right, the needle just goes in and out, leaving a hole but no thread through it... it winds up looking like a row of straight stitches on the left, but only holes in the fabric on the right. Please help- I am getting very frustrated and thinking that my foray into sewing was a bad idea.... Thanks! Koren
  • cannotfinemanual
Posted on Mar 14, 2008
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Simplicity Denim Star SW210 Logo
56 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Steve Allison
Steve Allison
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
