Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco Vienna not brewing
Our espresso maker is not making liquid coffee. However, it does let water out of the steam nozzle and the coffee grinder works fine. But the ground coffe is not getting any water. I took the whole thing apart to make sure the hose wasn't blocked... Nothing seems to work. Any ideas?
Dean
I wish I could post a solution, but this is exactly what happened to my machine after about a month of use. I don't see any clog nor a way to get to the moving parts that could create a clog. Unfortunate design.
Posted on Apr 24, 2010
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
I need instructions of how to clean the Saeco Vienna Superautomatica in and outside. We lost the manual.
-Rinse Brew unit under warm water, and let dry.
-Rinse coffee tray, water tray and water tank under hot water (may melt in dishwasher)
The rest coffee been tank and exterior needs to be washed with a warm cloth, just make sure it is not to damp, which could leave water drops in the grinder.
Feb 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Coffee and steam lights flash after using steamer and will not go solid
Hi
Once you have finished steaming, turn the steam button off, then open the knob and let the steam out. The water pump will turn on again and bring the temp back down. When the pump changes tone, the light will go off and you can brew again. It takes less than 10 seconds.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Re: no coffee comes out after the grinding and loading stages!
Sounds like your coffee grinder is grinding too fine. I would up the size of your grinder. The larger the numbers the coarser the grinds. Also, should descale the machine if you haven't in a while. One of these two things may help.
Also, if the above two things do not work you can try to clean out your grinder using the instruction #2 posted on the website http://cerinicoffee.com/Saeco_technical_documents.asp
Sales, Service and Information of Saeco Machines visit:
www.CeriniCoffee.com
Hope Everything works out for you.
Oct 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
103 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
