Question about Kenmore 43142 Front Load Washer
Front loading washer seal came out along with some sort of wire
On my kenmore front loading washer we were doing laundry when it started sounding like someone dumped a bunch of change in it when we went to check it there was a wire with a spring on one end and something else one the other and the seal is no longer in place. Is this a simple fix and if so how do you go about fixing it. This is Friday and I cant get anyone here till Tues and we are a family of 5.
    Sergeant:
  • 291 Answers
    Genius:
  • 1,550 Answers
It is simple fix only .You need to buy seal kit and replace it .
The cost will be around $70.
Posted on Nov 28, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
I am not able to wash any laundry. when I press start.....F1 flashes and a beeping noise sounds. I am unable to cancel it out, open door... anything. Nothing works.
Hello
F1 error and the beeping sounds in your Kenmore front load washer means that the Electronic control board has gone bad and needs replacement. You can buy the parts from Sears if you want to do the repair yourself. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Kenmore 46472 Front Load Washer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Super Capacity front loading washer that has stopped.
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
Front door seal
ITS REALLY NOT THAT EASY ,,, THEY MAY BE INSIDE BAFFLES DO NOT RECOMEND JUST LIVE W/ NOISE IF SOME ONE COMES OUT TO REMOVE UR LOOKING AT 250..+ JUST LABOR
Nov 28, 2008 | Kenmore 46462 Front Load Washer
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
My washer doesn't open...
The instruction manual suggests running the "drain & spin" cycle, because there is most likely water left in the machine.
Dec 15, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
