Question about Liebherr KIKNV3056 Bottom Freezer Refrigerator
Bottom of fridge always full of water
My liebherr bottom freezer refrigerator constantly has a pool of water in the fridge. I have tried cleaning the drain - makes no difference. Today there is ice on the back wall - which is not always there so maybe the temperature fluctuates, the ice turns to water and drips to the bottom of the fridge . The dial indicates that the fridge has a setting of 1 - out of a possible 4 - so cannot turn it down - any ideas?
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
  • 531 Answers
SOURCE: water collecting inside the bottom of the refrigerator
you have clogged drain
Posted on Apr 07, 2009
buddymcl777
  • 67 Answers
SOURCE: liebherr f/f, drain gully is retaining water, drain hole is clean
the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
Posted on May 05, 2009
  • 9 Answers
SOURCE: Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Posted on Jun 14, 2009
SOURCE: I have a Liebherr fridge freezer. Model n0 CNES
I left the fridge closed for 12 hours after cleaning and the back wall is now frost free.Great!! Lynn
Posted on Sep 09, 2009
How do I remove the back wall of freezer on samsung rb195acwp
Annonymous, what problem are you trying to solve? Is the water at the bottom of the refrigerator because the fridge is not cooling? If that then unplug the fridge, Keep the fridge and the freezer doors open after salvaging food items. Keep it unplugged for about 12 hrs and any ice buildup in the back wall will melt. You will see a pool of water on the floor. Clean that and the inside of fridge and freezer. Re-connect. You might get lucky!
Jul 29, 2014 | Samsung RB195ACWP Bottom Freezer...
How to tell the model number
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Nov 23, 2013 | Liebherr KIKNV3056 Bottom Freezer...
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Jul 23, 2010 | Liebherr KIKNV3056 Bottom Freezer...
Fan not working
I have a bosch fridge freezer, I bought it only 13 months ago and the fan has stopped working. How do I go about fixing this problem?
Nov 03, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
Blocked fridge drain
The pan being full doesnt affect the drain being blocked the pans not full anyway its constantly evaporationg it. I use a little air pressure to clear drain lines, than pur a diluted solution of water and a little bleach down the hole water should drain fast and not pool.
Oct 05, 2007 | Refrigerators
BEKO FRIDGE
Leaking what? And where from. If it is water inside you have a blocked drain if on the floor then you may have a hole in the pan on top of the compressor. If not water I have no idea?
Aug 17, 2007 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Liebherr KIKNV3056 Bottom Freezer Refrigerator Logo
56 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
