Question about Krups FME4 Coffee Maker
Water level lite is on ,wont start.krups coffee maker
Kurps coffee maker water level lite is on,wont start
    Genius:
  • 1,550 Answers
The problem is due to inline fuse in the wire that supplies power to the heating element might have been blown.
Just replace it .
Posted on Nov 28, 2008
    Sergeant:
  • 291 Answers
First unplug the machine for sometime.then again replug it and then check out.it must have got stuck.this will make the machine reset.
Where is the water sensor
There are two of them mounted in the middle of your face one each side of your nose. You observe the water level with them by looking at the water level indicator on the front of the coffeemaker.
Oct 25, 2015 | Krups FME2 Coffee Maker
How do I rest a krups 8200
Probably the magnet that indicates the water level to the electronics inside is not floating any more. Either replace the tank or wedge something plastic underneath the magnet to trick that the tank is always full. You will then need to check water level visually and not wait to be told.
Sep 20, 2014 | Krups Coffee Makers & Espresso Machines
I have a Krups FME2 coffee machine and when I fill it up with water, the screen shows that the water reservoir is empty? What the heck?
If there is a water level float in the tank it may be no longer floating, if you can shove a piece of plastic under it to lift it up that should trigger it to think it now has water.
Apr 09, 2013 | Krups FME2 Coffee Maker
How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups 453 - coffee is weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 09, 2008 | Krups ProAroma 453-42 Coffee Maker
Krups fmf 5 water leaks from the bottom of coffee maker
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Jul 23, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Can't operate it please help (Krups coffee maker)cannot get it started
Try following the manual directions, be sure to add water, coffee in the filter, plug in, and turn dial clockwise until red light goes on.
If this doesn't help, could you be more specific?
Jul 01, 2008 | Krups Aroma Control 229 Coffee Maker
How to use krups espresso machine
The metal nozzle under the rubber frother is plugged up. You can remove it with a wrench (it is threaded). I now wash mine after every use since mine plugged so badly I had to use wire to unplug it. Milk does that.
Feb 07, 2008 | Coffee Makers & Espresso Machines
Krups FME4 Coffee Maker Logo
108 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
