Question about Motorola Mobility RAZR V3c Cellular Phone
Charging the charging port on the phone is loose can't charge. how do i rectify the port? thank you
    Problem Solver:
  • 18 Answers
It needs taking to a good cell repair shop, shouldn't cost much
Posted on Dec 11, 2008
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
Aprilia 150 leonardo, flat battery and not charging, only 11.5 volt when running. Is it the rectifier and where is it fitted to bike? Thanks
Hi, J33pkk and the usual suspects are:
1. Voltage regulator/rectifier not grounded.
2. Engine ground wire loose or broken.
3. Faulty voltage regulator/rectifier module.
4. Loose or broken wires in charging circuit.
5. Faulty stator and/or rotor.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD Aprilia Leonardo 150
Jul 07, 2011 | Aprilia Leonardo 125 Motorcycles
Why my lg phone KP 502 is no charging the battery
if you have ensured that the charger is working, and the charging port is also fine,,,
then , know that the battery is bad and it needs to be replaced with a new and original one.
1.. to ensure that the charger is working, connect to a similar phone and see if it charges, if it works,then you'll know that the charging port of the phone in bad and needs to be replaced by a phone specialist
I ASSURE YOU THAT THIS WILL HELP YOU RECTIFY THE PROBLEM
Jan 19, 2011 | LG Cell Phones
Phone is in the charger and after charging for a little bit it stops charging and says "warning bad contact of charger" how do I fix this problem for nokia n97. Please help
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
Feb 25, 2010 | Nokia N97 Cell Phone
Charging port is not connecting loose receiver , must push down on cord to connect
Hello
The problem is from your charging as you have rightly said.
What you should is to open your phone,try adjusting the charging port to its position because it might have shifted
If the problem persists,then you will have to replace the charging port with a new one and your problem is solved.
Thank you for visiting fixya.
Feb 22, 2010 | Cell Phones
W375 charging
When you phone is not charging, it's either the battery is bad or the charging port is bad. There are two ways to it,
Try getting a universal charger or a desktop charger to charge your battery or take your phone to a mobile phone technician to check and rectify the charging port.
GOODLUCK
Jan 07, 2010 | Motorola Mobility W375 Cellular Phone
Charging port on LG Voyager loose
time for a new phone or some super glue
i suggest you not play with the phone as much when its on the charger
Jun 14, 2009 | LG VOYAGER VX10000 Cellular Phone
Charge
Yes}}}}}}} you can charge the phone from the usb port of the computer ...........
Jun 12, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Not charging N1100
i think the charging port might have damaged or the charging IC is gone ...
just give a try with the other charger ...
if the charging port is gone then you replace the port with the new one ...
if the charging IC is gone you must get the new one and solder it ....
just have a check after opening the handset check whether is there any loose contact inside near the charging port ...
make sure of which type of problem you have and then taking the necessary steps ..
any doubts reply me
i am always here to assist you
thank you
bye ....
Apr 10, 2008 | Nokia 1100
Motorola Mobility RAZR V3c Cellular Phone Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
