Question about Panasonic CT-27G33 27" TV
TV keeps shutting off and then on on its own
I am having trouble with a Panasonic CT-27G33W. The TV shuts off on its and then after a while will turn on again. Sometimes, when the TV shuts off banging it on its side or top will turn it back on but only for a while. Perhaps someone can help. Thanks, A R
  • Anonymous Feb 13, 2009
    I have a 32" Panasonic TV I bought in 2001 that, after being on for a couple of hours, will shut off on it's own. After two minutes it will come back on. Occasionally it will also make a clicking noise (but not at the time it shuts off). Any ideas?
    Scholar:
  • 168 Answers
U have a bad solder inside your tv or most of the time called "cold solder". if u have soldering tools, inspect the board inside for possible cold solder and resolder it.
Posted on Jan 15, 2007
I have a ct-36hl43 thyat when turned on it tries to come on but shuts down and the red power keeps blinking and the only way to stop it from blinking is to pull the wall plug whats the problem??
If you can find the Horizontal output transistor make sure it is not shorted, this set had a issue of repeated shorting of that part after just a few minutes and the cure for that is well known.
To trouble shoot you will need a volt/ohm meter and how to use it, the set if shorted will not always blow the fuse but will go into shutdown to prevent further damage.
Let me know your skill level and if able to use a meter etc or not.
Dec 10, 2012 | Panasonic CT-36HL43 36" TV
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
Apr 26, 2012 | Televison & Video
Want to know if panasonic tv CT-32G31 has a fuse...shut off and i am unable to turn it on
Yes! there is a fuse on the inside of the set, unplug set, remove back cover, and follow the power supply cord to the main board, fuse should be near by.
Mar 19, 2011 | Panasonic CT-32G31 TV
TV cuts out
Loose connections on power supply and vertical IC.Resolder
Aug 04, 2009 | Panasonic CT-32D12D 32" TV
Panasonic CT-30WX54 - shut off while watching
The Sleep timer might have got set accidentally. Try that.........
Apr 25, 2009 | Panasonic CT-30WX54 30" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
TV Shut off will not turn back on
the vertical i.c. is shorted, replace it.
Dec 20, 2007 | Panasonic CT-36D31 36" TV
Panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Jul 25, 2007 | Panasonic CT-32HXC14 32" TV
Panasonic CT-36D20 36 SHUTS ON AND OFF..by itself
maybe a bad solder connection around the flyback area or at the B+ circuit in the power supply
Nov 30, 2006 | Panasonic CT-36D20 36" TV
Won't turn off
it can happen due to overvoltage shutdown circuit. when voltage is too high, tv will shut down. it is possible that this specific model doesnt fit your local electricity network.
Dec 14, 2005 | Panasonic CT-36HL43 36" TV
Televison & Video Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
