Question about Exceed-RC RC Truck
Exceed rc - magnet was smoking
Hi
I was driving the magnet with my son and I think it went through a puddle. Started to smoke. Figured it was just water on the motor but then it hasnt worked since. Tried to charge it and still nothing. any ideas?
The smoke came from 1) you fried the Electronic Speed Control (ESC) unit 2) wires have shorted together, got hot, and burned together. You need to check the ESC and wires. Go to a radio control forum and ask. All the best Jeff - admin at rcgearing.com
Posted on Dec 22, 2008
Went through puddle during raining day,the car started smoking never shut off.It started up with no problem the next day,but later that night it shut off while driving and now won't start 2010 accent
When you say "now won't start" does the starter motor spin the engine the engine just never fires, or does the starter motor not even spin the engine? Do all the electrical accessories seem to work correctly? How deep was the puddle? Did the "smoke" smell like something melting, or might it have just been steam from water on the hot exhaust?
Oct 15, 2016 | Cars & Trucks
I have an 05 bora1.9tdi recently it's started to
It sounds likeyou have a Vacuum lead developing and the Pressure Sensor adjusted the best it could but it was not good enough
Apr 15, 2013 | Cars & Trucks
My Hero Honda Glamour (2008 byke without disk brake)is emmiting white smoke.
That seems a big job, did he say how much he will charge to do it?
I think, unless you are an engineer you will need a manual to do a job like that, although you may find one somewhere on the Internet, if I were to attempt that I would prefer to have a paper one, I could refer to as I went along.
Aug 27, 2012 | 2007 Hero Honda Glamour
I started my 2004 suzuki forenza after work today and it started badly and there was a lot of white smoke coming out of the exhaust. The check engine light started flashing. I got about 4 blocks away and...
It does sound like a bad head gasket. Did you vehicle overheat recently? Usualy there is a reason the head gasket goes out. Check to see if your low on coolant too. It probably isn't too bad yet because it stopped blowing white smoke but I wouldnt drive it anymore. Coolant will ruin the pistons and sleeves if you keep driving it. Hope this helps and if you need any help with anything, feel free to ask.
Sep 10, 2011 | 2004 Suzuki Forenza
I just went out in the mud in 4wd and had to get on it to get out of a puddle. Now where my 4wd drive line connects to my transfer case is smoking what could be wrong?
Does the transfer case work? Can you 4wheel? If you answered yes then wet mud and hot metal mean smoke.
If case doesn't work you blew it out.
Sep 24, 2010 | Dodge Ram 1500 Cars & Trucks
Electrical short, sparks and smoke!
Yes this is a fault that can happen, i do NOT think, that it is worth while repairing, when these controllers burn out, it's pretty much totaled. If you must, take it to a reputable service center, and ask for a "Quote" before proceeding with any repair, as repair may exceed the cost of a new one.
Apr 01, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Pop noise with thick white smoke from front end,
sounds like you might have a cracked cylinder and oil puddled up inside over night and when you started it..it blew out through the exhaust. White smoke means oil...black smoke means gas ,and blue smoke means both..if you cracked a water jacket your oil will look like a bubbly milk shake.....take a look at your oil.
Sep 08, 2009 | 2008 Yamaha YZF-R6
New bright 19.2v nicd battery problem
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Mar 30, 2009 | New Bright Remote Control Toyota FJ...
"service ride control" problem with '96 cadillac deville! loud clicking nose and smoke from exhaust!
The PCO 133 I believe is ABS issue. One of the sensors may have been ruined or disconnected after water trip. PCO135 i suspect is HVAC, or heating/cooling data. Some chip or part may have gotten wet. Does the air and/or heat still work?
The AC code is air conditioning related. Is there the word "history" or "current" next to any of the codes? You may have old codes. There are a couple of ways to reset the codes. But i'm not sure if that is necessary for your car. I suspect you may have to take the car to a dealer/mechanic; which might not be a bad idea considering you just went through a gaping 3 ft puddle.
hope this helps
paul
Sep 14, 2008 | 1996 Cadillac DeVille
Exceed-RC RC Truck Logo
310 people viewed this question
Top Exceed-RC Toys Experts
jasiel murphy
Tejodhar Atreya...
Tejodhar Atreya...
Mike Darragh
Level 1 Expert
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
