Question about Acer Aspire Notebook PC
At witts end
My laptop is just over 1 year old, an Acer Aspire 9100. Sometimes the fan gets a little noisey sometimes not. Recently it has been shutting itself off mid task, no warnings or beeps. Sometimes it can run for hours, sometimes for 15 minutes before it switches off, the battery seems to charge ok, It doesnt even get warm before it switches off. I bought a notebook cooler which has done nothing to help. Any ideas anyone please? Thanks in advance Jenny
  • jennifer sedgwick Jan 16, 2007
    No, sometimes Ive just switched it on and let it boot up, 5 mins later, its off again
    President:
  • 2,961 Answers
Give the vents round the side and underneath a hoover out first, then check in acer e manager, there you should see settings for your fan, HDD and hibernation , you can set the fan on all the time or default, check it's set correctly and see if you resolve the issue. Turn hibernation off and HDD idle shutdown off to see if any change in shutdown. Does the pc shut down in any particular programme?
Posted on Jan 15, 2007
I've had my acer aspire (5315) laptop for over 2 years
Sometimes, the CPU heat sink fan might get clogged up or faulty or stop spinning entirely. Make sure that the fan can turn properly.
IF YOU CAN, open the unit when the battery is disconnected and the power is not connected, then reseat the CPU Heat sink and re-apply a eye drop heat sink thermal paste onto the CPU. Reconnect and tighten everything again properly and adhere to the sequence in turning the screws back as per their numbering on the heat-sink
If the FAN has trouble spinning, doesn't turn at all or is noisy and runs irregular please replace the fan. The fan alone should cost about a few US $.
May 16, 2010 | Acer Aspire 5315 Notebook
Acer Aspire One, Screen turns strip-y grey/white
hi there, my sisters dell laptop does the same thing. My best guess is that a hard knock on the graphics card and knocked a few pins out of it. This is something that a average person can not do. My suggestion is to bring it to a computer shop and tell them that you think it's the monitor connections.
Jan 31, 2010 | Acer Aspire One PC Notebook
My 1 years old acer 6920 is will suddenly freeze without any symptom and will resume its function after few minutes. Sometimes blue screen show up after few minutes. Very unpredictable. Mostly happen when...
OS corrupted. dont worry. format your OS and reinstall it. YOu will find good service. i ahve my own acer aspire. i do formet every 6 month. i am not jocking. if done thumbs me.
Jan 06, 2010 | Acer Aspire 6920 Notebook PC
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
Like many others, I have an overheating problem especially with games. I am looking for a repair manual in order to clean and check the heat sink. The Acer website only posts Owners Manual. Any idea where...
it sounds like an overheating issue. download everest home edition andhave a look at the temperatures of the graphics card. the 7000 isntreally a gaming card, but it should'nt overheat without overclocking...
Sep 14, 2009 | Acer Aspire 7520-5185 Laptop
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Computer shuts down without warning
My first guess is that your laptop is over heating. Even with a fan underneath, if the bottom vent is clogged with dust, the CPU will still get too hot. Does your computer last longer when you run less programs? I would check for dust around the fan inside your laptop. There's a video on youtube showing an acer being disassembled:
Although it may not be your laptop specifically, hopefully it will head you in right direction. It would be a bad idea to blow the dust further back into your computer, so you may have to loosen some screws and buy a electronics duster from an office supply store, but it should solve the problem. I've ran into this a lot over the years, specifically with Acer and Dell computers. Hope this helps!
Jul 14, 2009 | Computers & Internet
Fit Keyboard to Acer Aspire 5630 Laptop
When you remove the old keyboard you can place the new one down and the cable should fall in the vicinity of the connector. Most laptop ribbon cables have a little plastic piece that you pull up to make inserting the end of the ribbon cable easier, When you insert the cable sometimes this piece goes down with it other times you have to "snap" it back in place. A word of caution, when pulling up on this piece it should not come off but just come up and a little off to the front or back. I sometimes have to use needle-nose pliers to get it in, but be gentle!
Apr 28, 2009 | Computers & Internet
Acer Aspire 5100 CD ROM problems
it could be an issue with the IDE controller detecting your CD-ROM have it replaced. this issue happens not only on Acer but on other brands too. It could be because Laptop CD-ROM's are not built tought like Desktop CD-ROM's.
Jan 21, 2009 | Acer Aspire 5100 3010 Notebook
Computer shutting off
I might be due to your registry file... you may want to check below link
http://etech.maiila.com/?p=24
all the best....
May 11, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
