Question about Onkyo DV-SP301 DVD Player
Onkyo DV-SP301 DVD player stuck in standy mode
Powering down does not work - cannot get it out of standby mode and drawer will not open
  • macusa01 Feb 06, 2009
    player won't come off standby
  • 3 Answers
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Posted on May 31, 2009
Hi, so i have the desay dvd player, and im having trouble changing the battery for the remote. the back of the remote says its 04A05 CAT.NO. 16-3901. dunno if thats helpful or not, anyway, i'd really...
If you turn the remote over there is a tab at the top push that towards the bottom of the remote and pull up. Once you have the battery cover off replace batteries with two AAA batteries. Click below for a copy of the manual. The battery replacement is on page 9 of 40 in the adobe document.
Onkyo DV-SP301 Manual
Mar 02, 2011 | Onkyo DV-SP301 DVD Player
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  1. Switch everything off.
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V Interlace Reset
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 26, 2017 | Onkyo DV-SP301 DVD Player
Re: Onkyo DV-CP500 DVD player stuck in standby mode (by 7 users)
Hi Yes, sorry just saw this comment. Swap out C7, C17 and C18 in the power supply. Also I would check if you are getting 9Volts to the motor control IC's pin 7 coming off of C005 on the Mechanism Board which is under the unit. The hole for the C005 cap was drilled into a very narrow section of the circuit board and has marginal connection at best.. mine stopped working because of this 6 months after I fixed the power supply.
Oct 23, 2008 | Onkyo DV-CP500 Multi-disc DVD Player
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Jan 20, 2008 | Onkyo DV-SP800 DVD Player
ONKYO DV-SP301
the play head of your device known as the ''lens'' is either dirty or bad thats why its selecting disc,try clean it with lens cleaner,if it still does the same thing call your technician,and tell him to change the lens for you.if he does the right thing ,it will work perfectly well.
Dec 13, 2007 | Onkyo DV-SP501 DVD Player
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
DV-C501 MECHA ERROR
I have actually had the same problem multiple number of times now and am going to suggest you a rather "crude sounding" solution!! First, atleast in my case the problem usually occurs when you turn the DVD player off while it still has DVD/CD inside and then turn it back on a little while later. This is how the "solution" works. I just disconnect the player and give it a good shake !! This somehow dislodges the "stuck" disc inside and voila, the player opens up after reconnecting and pressing the open/close button. Sometimes it takes more than one "good shake". Sounds rather severe but works everytime !!
Oct 04, 2006 | Onkyo DV-C501 DVD Player
Onkyo DV-SP301 DVD Player Logo
565 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
