Very slow printing and missing colours HP PhotoSmart 7762
My HP PhotoSmart 7762 stopped printing black but with no low ink warning. I changed the cartridge but it then slowed down almost to a standstill. It misses lines and colours but in a random way and now seems to be stuck in ''Printer calibration - load plain paper and press OK'' mode. When I do that the rollers whir once, the cradle moves once and then it all stops for 10 - 15 seconds. it then makes a slight whirring noise and stops again. Printing then starts one slight movement at a time with long gaps between each twitch. I have plenty of memory available and don't need to defragment. Is my printer dead?
Mike.
  • 4 Answers
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
JmmyPge697
  • 39 Answers
SOURCE: Photosmart c6180 printer is printing
You should first try uninstalling and reinstalling the drivers for the printer. If this doesn't correct the problem, try replacing the cables to the printer.
Posted on May 10, 2008
SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Hey - I have an HP Photosmart 3310 All-in-one and my black ink cartridge wasn't printing. I bought a brand new cartridge - and it still wasn't working.
So - I did the reset thing where you unplug the printer, wait 30 seconds, HOLD DOWN "#" AND "6" and plug it back in at the same time and PRESTO! the black ink is working again!
TRY IT!
Posted on Mar 19, 2009
beboybutiki
  • 126 Answers
SOURCE: I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Posted on Sep 23, 2009
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
HP Photosmart C5280 Mac: how to print only in black and white
Depending on your printer software there are two different methods to set grayscale and black ink only.
  1. Inside printer preferences, you switch to the Features tab. Here you should see grayscale in the bottom left corner. Once grayscale is selected you may switch quality to black ink only. Then press ok.
  2. In printer preferences, you click on the Advanced button. You should see a "Print in grayscale" option set to "Off" switch it to grayscale or black ink only and press ok.
As for with a Mac when you open the print dialog depending on the application there may be a link at the bottom left for the system print dialog. Here you should see a preset option. There is a fast draft black ink only preset. Save that preset and it should become the default option.
For more help, Give me a call at 1800-204-4427. I can help you out via phone.
Sep 14, 2017 | HP Photosmart C5280 Printer
I have a HP photosmart D7460 printer,when I bought it it had all the ink cartridges with it.After first install it told me that Cyan & light Cyan were missing & Black was incompatible as it worked...
you are lucky to have use the cartridges of your printer for 19 months. In my office experience, I am actually replacing the cartridges of my printers within a year. Just a regular life span of an ink refilled cartridge.
May 17, 2010 | HP Photosmart D7460 Printer
HP Photosmart 3110 All-in-one not printing black ink but colour
have you found a solution to your black ink problem??? I am experiencing exactly what you describe, no error messages, I have reset the printer, alinged, cleaned etc but still not a single drop of black ink but all the colours are working fine. if you know what was wrong please let me know.
R
Jan 20, 2010 | HP Photosmart 3310 Printer
Suddenly stopped printing in black though colour is OK.I've tried all the usual things!
the ink head is probably jammed with dry ink. wihen the head is jammed, a lot of ink will pool at the bottom right of the printer. clean that pool, and dab the black ink head with a damp paper towel, but do not rub. blow the ink head with a can of compressed air. run a nozzle cleaning, and nozzle check until the printer is printing better. the nozzle check prints out grid for each color. if the grid is complete the printer is fine. sometimes a few horizontal bars will be missing and cannot be cleaned.
Nov 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP Photosmart C5180 In Cartriges Empty
uninstall the software and reload it it will mostly fix your problem.
if still the problem presists .
feel free for further assistance.
thanks
Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have a hp printer photosmart 7762, during traveling my power cable and tried every way I could to buy a secnd hand including buying another similar printer which I failed. Please help me. **** nazymharris@ukgateway.net
Oct 28, 2007 | HP PhotoSmart 7760 InkJet Printer
187 people viewed this question
jasbo
jasbo
