Question about Radio Communications
General lee squeling
When I key my mic up it transmits a squeling noise, if I hold the key for about 10 seconds it goes away, any help would be greatly accepted
  • sallad420 Dec 05, 2008
    thanks, you put new antennas on for me, it works great
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    probly a bad ground? the export radios have floating chassis anyway. is this a new radio, older? whats been changed, or is this a new setup?
    Novelist:
    Champion:
  • 211 Answers
For Goodness sake. I had no idea this was you ( I won't mention names of course) I am happy all is working well. Have a great week.
Ed
Posted on Dec 05, 2008
    Novelist:
    Champion:
  • 211 Answers
YOu need to make your your swr's ( antenna match ) are correct. This radio is subject to that problem if your swr's are wrong.
I Hope this helped
Ed Meshechek
Radio Man
NC Electronic
PO Box 1696
414 6th St
Mills, Wyoming
82644
307-266-4675
wyoed1@aol.com
Posted on Dec 03, 2008
General lee cb gets hot and stops transmitting and receiving.
Connex general lee - Mauldroppers CB Radio Forum
www.mauldroppers.com > Citizens Band Radio > Mobile DiscussionOct 23, 2012 - 13 posts - ‎7 authors Thread: Connex general lee ... amps and is getting cookin' hot when key'd for as little as 30 seconds, lol, truckstop hack job comes to mind lol.
Oct 02, 2015 | Radio Communications
My general lee cb radio won't transmit... i can receive can any one help
How old is the radio? Try another Mic. If that does not work then your radio need a service tech.
Oct 12, 2014 | Radio Communications
Galaxy DX 55HP stopped transmitting, but will receive. When the mic is keyed the power meter goes past max and wont transmit. Tried different mics and no difference
connect to a meter. if there is rf power on a watt meter at full wattage. then the am regulator transistor is bad. less than $5 part.
Mar 29, 2014 | Galaxy Radios DX55HP 10 Meter Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
When I depress the transmit button the cb puts a squel out to other radios on the same channel yet I have no problem hearing transmissions from the other radios
It sounds like the mic either has a problem, or its wired incorrectly for that radio.
Try a new mic, and make sure it's wired for that radio.
Also, if you have talk back then it's too loud, or your mic gain is too high.
The type of radio would help me know weather or not it could be the mic wiring.
Oct 20, 2010 | Radio Communications
CB Squeal When Transmitting
I believe the coiled coax may indeed be the problem. To check, try a temporary rerouting of the cable which eliminates the coils. Dave g.
Dec 20, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Connex 4300
Check for proper shielding,ground, turn mic gain down, move mike farther away from radio, turn off other accessories nearby-ie.-am/fm radio
Apr 02, 2008 | Connex 4400 320-Channels Base CB Radio
Grounding the antenna bracket is extremely important, if it's bolted into the metal frame or fender it should be OK. The coiled coax cable could be the culprit but that's only a remote possibility.Try running a separate groung wire from the radio mounting bracket (or one of the radio's cover screws if not using a bracket) to the CLOSEST vehicle ground...keep this a short as possible. Your problem is definitely caused by insufficient ground at either end of the coax, with the antenna side being more suspect.
Mar 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
Radio Communications Logo
88 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
