Question about LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive
My LaCie big disk extreme+ 1000GB isn't starting and I don't know whats the problem, i doesn't want to boot up. What can I do to get it to start. Its been working fine for a year now and today when I opened my computer it did not want to read it
  • slowwine1982 Dec 26, 2008
    how does the power supply look?
Hope this helps??!!
Posted Oct 13, 2006 - It's not the drives that fail, it's the power supplies... They fry after about 3 months-1.5 years. LaCie sells replacements for about $16-$20, dpeneding on the model. We have over 20 of these drives, and here's how you know: the drive spins up, then down - it tries to mount, data transfer will freeze, etc. Just put another power supply on it, and 9 times out of 10, it's fine. Of course, any drive can fry on you, but these have proven to be extremely reliable under some of the hardest use imaginable.
Posted on Dec 13, 2008
LaCie Hard Disk Quadra Setup Assistant
try this link
http://www.lacie.com/support/drivers/driver.htm?id=10145
Aug 29, 2012 | LaCie Big Disk Extreme with Triple...
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Need to reload program to operate Hard drive
if you mean operating system program
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 11, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Lacie big disk 2.0 usb
For anyone with a Big Disk drive that doesn't get recognised by Windows and gets a TUSB 6250 message in Device Manager, the cause is very likely to be the power supply. Although the drive will be powered up, it is not spinning at the correct speed. I tried all of LaCie's technical support suggestions, some of which are outlined above and none worked. They finally suggested getting a new power supply. This solved the problem (Wattac, £22). This problem has affected a lot of LaCie Big Disk owners...
Mar 26, 2008 | Computers & Internet
LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive Logo
459 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
