Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna is full of beans but the bean light stays on
I have a Saeco Vienna machine, and the bean light indicator came on. I added more beans, though it already seemed to have quite a few. Now it is completely full, but the light will not reset, so the machine won't do anything. We've just moved and our stuff is still in boxes. I can't find the manual to know what I need to do. Can you help? Thank you!!
  • 1,199 Answers
The sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Posted on Dec 08, 2008
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder settings for Vienna Deluxe
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Jul 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
Nov 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
168 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
