Wireless connection fault
I recently purchaced a azurewave wireless rooter it momentarily lets me connect to the internet then almost as quick throws me out. there is another wireless provider in range that i have no problems connecting to any ideas
  • Marlo Marinakis
    Marlo Marinakis May 11, 2010
    Try using windows wireless
  • Dominic
    Dominic May 11, 2010
    Doesn't sound like the router is configured right... Do you have Universal Plug-n-Play installed on your computer? Is it the only router on your network? Have you attempted to change the channel the router operates on?
  • 41 Answers
Hi
the problem is in router u need to increase the mtu size and channel of the compter ...
log in to router page and change the setting ,,,and make sure the router is not kept device that sends and wave signel ,,like radio TV etc....
if these setting are done the problem would be resolve
Posted on Jul 22, 2009
I cannot connect to the internet. I am using a netgear rooter. Although I am connected to the router I cant get through to the internet
moz-screenshot.png1) Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click correct Local Area Connection by identifying correct network card and click Properties.
4) Select Internet Protocol (TCP/IP). Click on Properties.
5) Then try assigning the following values (default) and Select OK.
Nov 18, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
I need a technical assistance to set up wireless connection of my new laptop with Belkin G Rooter. WLAN/' LAN MAC ADDRESS: 00173FOC265E
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dlink help!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
The linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
May 31, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
INternet and router problems
Have you changed the configuration of your internet at some point? In Vista I think you can change them somewhere in Control Panel under something like "Internet options" or "Connectivity"...
Ensure that all settings are set to allow full speed through to your system.
Another thing is that some sort of Antivirus software may be blocking some of the internet connections, check the confuguration on your Antivirus software incase it is blocking internet signals.
Hope this helps!
Dec 27, 2008 | Computers & Internet
My belkin light is on but the internet connection to my laptop keeps breaking up consistently
This sounds like it is probably the networking cables as your PC is directly connected so shouldnt have problems with net access. Get new cables as a first step :0)
Jun 07, 2008 | Belkin (F5D7230-4) Router (587009)
I can not get on line
When you plug in the network cable, ensure it is plugged in correctly to the network card and into one of the router's ports at the other end. The LINK light should light up at either end (computer end and a tthe router) and flash when data is being sent or received. Then on your computer, (for Win2000/XP) go t Start, Settings, Network connections, "Local Area connection" for your card, then click on "Properties" then scroll and double click ''internet protocol' then select obtain ip address automatically. this will assign your computer with an ip address given from the adsl modem. all other settings will then assign automatically as well which should give you access to the internet thereafter. What you could also try is from one of your working wireless computers / laptop, see what IP address and gateway addresses have been assigned by the DHCP host (automatic IP address assigner), to helpyou work out where the address is coming from, it should be coming from the adsl modem. check your address by going to Start, settings, network connections, local area connection, then click on the support tab.
Apr 02, 2008 | D-Link Wireless
I CAN CONNECT WITH NO TROUBLE TO THE INTERNET THROUGH MY ROOTER HOWEVER WHEN I TRY TO CONNECT THROUGH MY WIRELESS WRT54GS I CANNOT I GET A MESSAGE SAYING THAT IT CAN NOT FIND THE SERVER OR INTERNET...
what exactly are you trying to connect to the router? They usually have default passwords, such as 'admin'.
If not go to 192.168.1.1 on your computer when connected to the router, and leave the username blank and the password as 'admin'.
Then go to the top tab and change or remove the wireless password. If you mess anything up, just click the reset button on the outside of the box for 20 secs.
Mar 30, 2008 | Linksys Wireless-G WRT54G Router
I cant log in, PLEASE help me.
first ..you do have your own rooter dont you?
the way you explain this problem sounds like you just logged onto which ever connection you found! did you or afamily member set up a commection using belkin54g?
back to basics!
in order to connect to the net with any device...PC (if you dont have a pc how did you send this post?)...Wii PS3 first you need to install and connect to your own internet connection device i.e.ASDL Broadband rooter..call it what you want
lol it sounds like you've been useing your next door neighbour's unsecured internet connection...nice cheap way to get connected.....but a bit of a bummer when text door go on holiday
i suggest setting up your own rooter (withyour own password)
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
