Question about Mitsubishi VS-5043 50" Rear Projection Television
Vs-5043 No Filaments lighting on any of the guns
I have sound and high voltage but my gun don't light, any thoughts/
    Genius:
  • 1,153 Answers
Yes you have no High Voltage, and you have filaments if you look at CRT's and they are dimmly lit on neck of tube.:::::This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Posted on Aug 26, 2007
Wont heat enough to solder
Hello, does your solder iron --Weller- humming? Also, is the solder tips the right tips for you Weller woldering gun? Are the tips tightened on the end of the solder gun prongs?
Well, if it is humming there is internal short in the windings inside of the gun. Don't mess with. Recyle it by taking the copper, brass, aluminum, and other metal out. Now, if it is not humming.
Make sure you have right tips, make sure that the tip is tightened in the soldering gun prongs.
The working principal of these soldering guns is that they work on low voltage and very high current. The current is regulated to keep the tip from burning into. Just enough current to heat the tipe to a certain temperature.. It can shock you but there not enough voltage with current but it will hurt. and could burn you. Be careful and lots of luck...GB...stewbison
Aug 04, 2011 | Weller Standard Tip: 7200
No picture, high voltage cable sparks at left tube/gun at turn on
It sounds like you have a shorted picture tube.
You should call a good TV Tech to confirm this and get an estimate.
Jul 29, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi vs 5043 no picture
have the tubes checked out you may have a loose connection
Jul 15, 2008 | Mitsubishi VS-5043 50" Rear Projection...
No picture, no pwr at color guns, no sound, pwr..
They have good sources. they will contact you soon they usually are pretty fast.
Apr 05, 2008 | Mitsubishi VS-5043 50" Rear Projection...
No picture, no pwr at color guns, no sound, pwr light on
Push in the menu and input buttons on the set and hold them in for 8 seconds together and see if the led blinks a two digit code, then let me know what happens.
Apr 05, 2008 | Mitsubishi VS-5059 50" Rear Projection...
VS - 5043
1. SHORT DETECT SHUT DOWN (PIN 15 OF IC700) CHECK FOR OPEN L902 PART # 351P070010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB. 2. SHORT DETECT SHUTDOWN (PIN 15 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 MAY ALSO BE OPEN BECAUSE OF THIS). 3. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR A LEAKY D5A09 PART # 264P244030 OFF PIN 6 OF IC5A01. 4. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR LEAKY D5A21, PART # 264P045040, IN THE BEAM PROTECTION CIRCUIT ON THE MAIN PCB. 5. CHECK FOR LEAKY Q5A03 AND/OR Q5A04 BOTH PART # 260P559050, IN THE HIGH VOLTAGE DETECT CIRCUIT, ON THE MAIN PCB.
Aug 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mits ws-55805 No sound no Pictuer
FIRST CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010 IF STILL NO HELP PROBLEM CAN BE INTERMITTENT (TEMPERATURE RELATED) CAUSED BY IC7D04 PART # 275P245010 ON THE DOUBLER PCB THIS WOULD BE A THIN VERTICAL LINE IN CENTER, IF GUNS WERE ON.
May 21, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Vs-5043
Jan 11, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
