Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Installed water line and filter is in, no leaks, water does not dispense
    Sergeant:
    Champion:
  • 311 Answers
Need to purge out air- just hold down paddle till it comes out.
Posted on Nov 28, 2008
Why is my side by side leaking water from left wall after replacing water filter inside on right side?
The problem is the water line to the dispenser is broken. The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 27, 2012 | Amana Refrigerators
Why is my refrigerator leaking water after changing water filter?
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water leaks from dispenser
Bad water filter or weak water inlet solenoid. Water line to back of fridge goes to inlet solenoid valve. Check it first. Would help to know the manufacture date. If it has a filter at bottom of fridge it will cause leaks and low pressure to dispenser if not changed each year.
Sep 11, 2009 | Refrigerators
Question about water leaking on the floor under fridge
remove and reinstall water filter, possibly o-ring got sideways during installation.
Mar 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
53 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
