My DVD/CD Rom will not eject.it says it is working properly but i still can't get to eject. I have tried both pressing the button and going to the pull down menu in My computer and pressing eject. Please Please help me.
    President:
  • 2,110 Answers
Your Cd-Rom seems to be jammed.Take a sharp object like needle and press in the hole bellow the eject button on CD-Rom.Then it will eject...
Posted on Nov 28, 2008
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
DVD/CD will not open on my HP Pavllion s7000 what may cause this?
go to computer and try to right click on CD/DVD Rom and then select Eject there.. if this doesnt helps u then u would have to manually release the CD/DVD rom.. just below the tray there is a Small Hole .. use a Needle or any other device that may go in that hole.. try to press on eject button there.. and try to press using needle.. try doing so 3 - 4 times.. there is a latch that needs to be released to open the Tray..
this normally happens if the eject functionality of the tray is not functioning properly.. if ur computer is under warranty .. get the CD/DVD rom replaced.. let me know if this resolved ur issue regards, guru
Apr 20, 2010 | HP Computers & Internet
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
I have a DVD door that won't open. I tried to
Unless I am mistaken there will be a little hole on the door (or near it). That is the manual eject, use a pin or a paper clip to press the button inside.
Feb 12, 2010 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Eject Problem..
1. right click on the drive. 2. press 'Eject' option. this will intern send the software interrupt to the drive to open it, if your cd-drive 'button' is not working. thanks.
Jun 08, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD RW Drive will not eject
Perform a system restart on your PC. As soon as it comes back up, hit the eject button..
May 15, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
233 people viewed this question
Alun Cox
David Payne
David Payne
