Question about Maytag Washing Machines
Washer fills but then will not go thru cycle.turned dial to every stage of cycle and get no results.
    Sergeant:
    Champion:
  • 311 Answers
Don't know brand, but most all will not work unless lid switch is functioning. Check yours. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Washer will fill up and then nothing almost sounds like the timer
I assume the timer is mechanical instead of electronic--try turning the dial slowly through the full cycle positions. You should get motor operation at some points along the dial. If the motor never reacts, look for a circuit breaker button on the motor near it's wiring entry. With the power plug out, try turning the motor shaft to make sure it is not bound up. If the motor does run at points, then probably the clock motor on the timer is bound up.
Aug 02, 2009 | Washing Machines
My top load washer after the washer fills with water and starts the cycle it stays at the agitte stage. have to move the dial to drain and then move the dial to rinse etc. is this the cycle dial that has...
It sounds like the timer motor has gone out on your timer and you will have to replace the timer itself. If you get the model number and go to www.sears.com you can pull up a diagram of your unit and order the timer for it.
Jul 22, 2009 | Washing Machines
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Cycle never finishes.
we have an issue with one of three things
on the sides of the lid the hinges are bolted to the lid with 2 screws on each side
ferify that the secres are tight
if so then you have a lid switch that needs to be replaced or the water pressure switch in the console is bad
Apr 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
