Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
How can I adjust the top burner flame on my Jennaire dual fuel?
I have a very low flame on 3 of 4 burners. Is there a procedure to adjust the flame on the Jennaire Wolf Creek 30" dual fuel top burners??
  • fadiasad2 Mar 08, 2009
    I have the same exact range and the same problem and cannot figure out how to adjust the flame on these burners I even took the top of the range looking for a screw to adjust the gas but there was none, mine even goes out when you turn the knob to low, I would appreciate any help.
5 Suggested Answers
  • 183 Answers
SOURCE: Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Posted on Jul 28, 2007
catriver
  • 878 Answers
SOURCE: Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
Posted on Sep 11, 2006
Buffalo12980
  • 625 Answers
SOURCE: burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Posted on Aug 30, 2007
bigg t
  • 640 Answers
SOURCE: burners with yellow tipped flames
are you using propane or natural gas?if propane you need to clean the burner real good.propane burns very dirty and the soot clogs the burner.if natural gas is used look on the end of the burner,youll see an air shutter all you do is turn the shutter to increase or decrease the air flow.
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Posted on Apr 06, 2008
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
My LRG 30357ST gas range burners flame are too low, How can I increase them?
Do they go out on low setting? If so then your regulator is faulty, Never adjust flame higher unless reg. checks out fine. Even then get a qualified tech to do that
Feb 04, 2013 | LG LRG30357ST (Dual Fuel) Stainless Steel...
When ever we get a full 20 lb. tank of lp gas, our 3 burner weber grill has a very low flame and it goes out frequently with low heat until it runs for a long time, then it runs normal.
Hello.
It sounds like your regulator is not quite right. Try a different one, or just replace yours. New regulators are inexpensive, and are available at Lowe's/Ace/Similar.
Best regards (and happy grillin'), --W/D--
Aug 18, 2009 | Grilling
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Burner Problem
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
464 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
