Question about Cameras
Access comes on then it says turn the power off and on again and will do nothing else.
  • 586 Answers
HI,
    The main board which called SY board being malfunctioning.And you have to replace the main board.For this plz contact nearest possible SONY SERVICE CENTRE.You didn't mension Model No. here so that i was able to give you the part number too.But anyway it will solve frm there easily.
 Thanks, And dont forget to rate.
Posted on Nov 28, 2008
Print carriage access door is open or ink cartridge cover is open. getting this message but nothing is open!! It says to hold down ok button for 5 seconds but nothing is happening. I turned off but it...
Turn off your printer
Open the cover
1 move the cartridge carrrier manually to the center manually with your hands from left torgiht ( 5x )
2 .Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean .CLean also the area where you return your cartridges make sure its clean OK .
3 >return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
close thecover
try to turn it back on
in case nothing happens
remove all the parts cartridge ,black box paper power supply
lift the printer up turn it up side down make sure the cover is open when you lift it up and turned it upsidedown
so any foreign material will come out
Shake it for 5x
\return all the parts
try to power it on
Hope it help thanks
May 26, 2011 | HP Officejet Pro L7680 All-In-One Printer
My playstation3 will turn on looks like it is working but my tv screen is blank nothing comes up
Try to reset the video settings on the PS3 and also make sure the cables are all attached and that you have the TV on the correct input source.
Turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up.
If there is anything else please post back.
Regards.
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
Look my problem is that i have a sharp 56dr650 i replaced the lam p and it worked for 3 days then i turned it back on and nothing happems. No backlight not sound no nothing. The power light comes on...
within the 3 days of replacing your lamp to when it stopped working, did you open the access panel for the lamp again? If you did, the interlock switch might not have engaged when you put the panel back on. Make sure the switch is in the O position, then try powering it up.
Nov 05, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Can't get the computer to turn on
can you access the battery? I use to have an acer if memory serves me correct and I'd have to remove & then reinstall & that would do the trick???
Dec 15, 2017 | Mirus Computers & Internet
Wheres my main menu
Mine did the exact same thing here is how i fixed it. Access recovery menu.
1. turn off ps3
2. hold the power button down; the system will turn on and turn off once again.
3. once the system has been shut down, re-press your finger until you hear 2 conscutive beeps (2 quick beeps)
4. when you hear the 2 beeps take your finger off the power button
5. you will be prompted to plug in your controller via usb and then hit the ps button
6. the recovery menu will pop up
Now i tried the Restart System and it didnt do anything. I was not sure which one to select, so I then clicked Restore PS3 System. I lost everything, but I got it working again!!
Nov 01, 2008 | Sony Playstation 3 (PS3) Console
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
When i turn on the power.....it shows access on the screen and then asks to turn the power off and on again......i follow it but nothing happens ...it keeps on repeating it..
turn on take the end of the lens eand gently pull and twist you may hear it click but dont force it then turn off and on again and this may solve the problem.
Jun 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pc-chip m957g
sounds like the motherboard has failed. I had those same symptoms this summer. Replaced m/b and it's good again.  Did you count the 'continuous' beeps? That's a code to say what is wrong.
Oct 14, 2007 | Pc Ware PC CHIPS: PC-Chip M957G...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
