Question about Ovens
Thermador Wall Oven C301US Can't find High Limit Swtich
Hi Rotu,
I looked at your instruction to fix a thermador c301Us when the heat does not go on with you use the self cleaning. I can't find the ghigh limit switch. I am taken of panels by the control panel. But only see alot of wire. Nothing with a red button with wires coming out it. Can you tell me where in the oven it is.? This is my last option before I get a repair man.
Thanks so much.
Beverly Beaulne email beaulne@telus.net
4 Suggested Answers
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
tbreeze47
  • 3083 Answers
SOURCE: After performing the self-clean on
The following website has the diagrams of your unit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=233139&diagram_id=194244#d194244
Part #23 lists a Thermal Repair Kit, and might fix you up, but the website lists the part as unavailable. However, part #26 is the thermal sensor.
I've seen hi-limit switches, but couldn't run on down in the oven diagram. It might be on another diagram, if you look around.
The thermal sensor could be the bad component, and on on the right rear of the unit, looking from the front, guaging from the diagram.
Hope this helps.
Posted on Jan 26, 2011
  • 195 Answers
SOURCE: Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
Posted on Dec 02, 2011
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
May 20, 2011 | Thermador C301U Electric Single Oven
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2010 | Thermador SC302T Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Thermador C302U Electric Double Oven
Thermador wall oven doesnt heat up after being self cleaned
This may be the thermal fuse mounted on the back panel or you may have a failed control. We rebuild Thermador control boards at www.fixyourboard.com
Jun 02, 2010 | Thermador C302U Electric Double Oven
I have a Thermador double convection oven, that I'm getting a f54 code plus a lockout indicator readout at times. Whats that all about.
because you used self cleaner funtions that burn will cause machine over heat try to remove the oven and check the thermo limit in the back of the oven
Jan 12, 2010 | Thermador SMW272 Electric Double Oven
Oven lock won't open
because you used self clean funtion that cause the oven over heat.so check the high limit fuse in the back of the oven
Jan 10, 2010 | Thermador SMW272 Electric Double Oven
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
