Lamp replacement in Panasonic Model # - PT-61LCX65
You had noted that you could send the directions by email on how to change the lamp out for the Panasonic Model # - PT-61LCX65. COuld you send them to me as well?
ralphbrowning@browning5.com.
Thanks Slinteriors!
Best Solution posted on Mar 03, 2008
Slinteriors
Rank: Guru
Rating: 89%, 2696 votes
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
    Top Expert:
  • Televison & ... Master
  • 75,767 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Mar 09, 2017
Slinteriors
  • 8617 Answers
SOURCE: Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Posted on Mar 14, 2008
  • 1694 Answers
SOURCE: thank you
Check pico fuses in power supply with ohmmeter......
Check current-limiting resistors near convergence IC's.......
Measure B+ supply voltages ( use manual)................
Posted on Apr 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: thanks for the help
check the resistors right next to the ICs usually the 1.5ohm resistors will open when the ICs go out
Posted on May 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: LAMP RESET PANASONIC PT-61LCX65
I am sending the instructions to your email address now.
Posted on Jun 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Jul 26, 2008
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
LAMP REPLACMENT
Lamp.
POWER button.
Dec 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65 Lamp change and reset
Oct 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Note:
power strips.
the outlet.
Note:
Note:
handling.
Lamp.
POWER button.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Jun 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
239 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
