Question about Microwave Ovens
Microwave oven heats sporatically.
I have a over the stove Frigidaire microwave (model FMV156DCA) that will heat normally for several cycles, then then next time i go to use it, it will not heat.  For a few weeks i was able to unplug the unit for 30 seconds, and it would then work again.  But now that is not even working.  I checked continuity on the door switches and they seem to be normal.  Anything else to check?
  • 2 more comments
  • drsutter Dec 02, 2008
    The Turntable and fan always come on and stay on.  It's not a situation where it starts to heat and them stops in the middle of a cycle, it either works the whole cycle or not.  Lately, it doesn't heat at all, but still the fan, turntable and light all work.
    Thanks
    Dan
  • drsutter Dec 06, 2008
    Nothing unusual with the noise, normal sounding.
  • William Miller
    William Miller May 11, 2010
    Any unusual noises? Is
    it louder or quieter than usual?
  • William Miller
    When you hit Start to
    cook, do the turntable and cooling fan always come on?
    When you encounter the "no heat" situation, do
    the turntable and cooling fan run, or do they stop?
    How about the inside light?
    I think I may know
    what's wrong, but I want to be sure.
  • Microwave Ovens Master
  • 9,098 Answers
Since you say it sounds normal, the first thing I would suspect is a loose / corroded connection of the "FA" (right hand) terminal of the magnetron.
The photo I've attached is a worst case scenario, but even if the terminal is a little loose, it can cause a "no heat" condition.
If it's not too charred or corroded, it can be squeezed with pliers to tighten it. If it is too far gone, the solution is to either install a new connector or solder the wire directly to the terminal. But in either case, the metal must be clean and shiny.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's not the magnetron, then the next suspect would be a bad connection elsewhere in the high voltage.
Posted on Dec 06, 2008
Electric frigidaire stove model:RE-38S serial :61CD4495 oven wont heat. checked;continuity,cord,wiring and outlet all was good. how do i fix this problem?
can not say as do not know if it is a conventional stove oven or a microwave oven . I would call a local repair service
Sep 13, 2017 | Frigidaire Microwave Ovens
Frigidaire microwave professional series
If its the magnatron I suggest a technician
Apr 18, 2014 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Mar 20, 2009 | Frigidaire FMT148GP Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
