Olympus Vg-110 12mp Digital Camera Silver Vg110 228175 Logo
A
Anonymous Posted on Jun 03, 2012
Blank screen on Olympus VG-110
Screen is blank and shows no image but pictures are being taken (show up when plug into computer) what can I do?
5 Related Answers
Anonymous
  • Posted on Oct 30, 2007
SOURCE: transferring images from Olympus Master Folder
You have to buy the upgrade to Olympus Master 2, to be able to burn images to a disc.  Olympus Master doesn't allow you to.  I get around it by manually saving my images in an additional folder on my computer and then burn them to disc from there.  It's a slow process and very inconvient.  Good luck.
A
Anonymous
  • Posted on Dec 04, 2007
SOURCE: Olympus 720 sw LCD Screen blank & white
Just in Time for Christmas then!
So decisions - live with out the screen- it appears to be a connexion failure or a main board failure.
Or replace the camera - a repair will cost almost as much.
Anonymous
  • Posted on Jul 19, 2008
SOURCE: how to activate time and date stamp on the pictures taken with olympus x-840
Well, not really a solution. More like clarification.
Olympus does not provide a date/time stamp on pics taken with this camera (f310/x840), so, no solution, just knowledge....
Randy Morton
  • 479 Answers
  • Posted on Aug 22, 2008
must be transferred to a computer folder then the cd
Anonymous
  • 919 Answers
  • Posted on Apr 07, 2009
SOURCE: olympus stylus 725 SW has gone blank
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $128.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning...
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
1helpful
There is straight white line in my Olympus VG-110
Does the line appear only on the screen or on your photos or both ?
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
WEIRDEST PROBLEM
Your battery may be low on power.
Buy new batteries.
Blank screen
did you press the disp. button?
Showing file names on the screen
while your camera is in playback mode.. check the option to show the OSD which'll also show ur image file name...
Pictures Are All Black
I just posted a similar question I have a olympus Fe-110. I can see old pictures through the view screen, but when change the setting to take a image its all black.
Thanks
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
2answers
Fujifilm finepix a303
A bit more explanation please Stevie Is the Screen really blank[black] or can you see shadow images. Or Is it White blank? And can you still take pictures even when the screen is in this state. Tell us more
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
