Vertical lines print crocked and not very sharp
    Genius:
  • 1,550 Answers
What is your brand and model of your printer ?
Have you tried print head cleaning ?
Posted on Nov 28, 2008
  • 734 Answers
Give detail about model number.
  • futureloginn
    futureloginn Nov 28, 2008
    To reset the Internal Waste Ink Pad Counter:
    Turn off the power.
    Tun it on again whist holding down both the paper & ink buttons.
    When the paper light starts flashing, immediately release both buttons and then hold down the ink button for at least 10 seconds.
    The printer should self-check and work normally again.
  • 146 Answers
More info Please
  • Patrick Shaffer
    Patrick Shaffer Nov 28, 2008
    uh ok.. I got 6 bucks for free...
Creates a line when coping and printing on the pages
vertical line or a repetitive horizontal line? Please describe in fullest detail what yo're getting.
Feb 13, 2014 | Sharp MX-M283N Copier
Vertical strip of black lines on copy
PULL THE INK CARTRIDGES OUT AND VERY GENTLY WIPE THE CIRCUIT BOARDS LOCATED ON THE BOTTOM WITH A VERY SOFT CLOTH ....THEN GO THRU THE CLEAN UP MODE IN THE OPTIONS .
Jun 21, 2009 | Sharp AM-900 All-In-One Laser Printer
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Sharp Tv 25E-M50
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
May 21, 2008 | Sharp 25N-M100 25" TV
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Oct 13, 2007 | Sharp 27G-S60 TV
14 people viewed this question
k24674
jasbo
jasbo
