For some reason we have a hard time opening and closing the door of our washer. It started 5 days ago. Does anyone know what we can do to fix this?
It may be sprung in the hinge or there may be a tiny piece of debris causeing the door to hang when being opened or closed.
Testimonial: "Jess was extremely helpful and his suggestions worked. "
To fix I would suggest cleaning all edges of the door and the seat (area in which the door rest). Use a finger and feel all edges to check for debris and or an irregularity. If none are found visually check the same edges for chipped or scatched paint that may indicate a point of contact. If none are found open the door and gently pull on it to see if it has play or movement. If a lot of movement is discovered then a new door or possibly a new hinge should do the trick. I hope this helps and good luck.
Thank you Jess but if that is the case how do we fix it?
