Question about Kitchen Ranges
Maytag stovetop burner not igniting! - Kitchen Ranges
    Sergeant:
    Champion:
  • 311 Answers
No spark, or spark and no flame? I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Igniters won't lite on stovetop
Check the wiring connection to igniter. If electricity is reaching the igniter and still nada, then the igniter is bad and needs replacement.
Oct 26, 2015 | Kitchen Ranges
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
One front burner ignites but the igniters continue to spark. when all other burners ignite the igniters immediately stop sparking. this problem started right after spilling some water on burner.
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
Jun 06, 2010 | Cooktops
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Stovetop burners won't ignite. Piezoelectric non-operational
each ignitor is seperat, but it does not take much water to get them to not ignite
Nov 17, 2009 | Kitchen Ranges
One stovetop burner does not initiate igniter sparking.
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
Feb 14, 2009 | Viking VGSC306-4B Gas Kitchen Range
Stovetop stays hot when burners are not on
Is it a glass top. If it is, glass will absorb the heat. It will cool off after some time. That is normal.
Dec 18, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
