Question about Sony KV-27V42 27" TV
Bad color. Too much green?
My TV's picture just went bad. Looks like theres to much green. any thoughts? simple fixes? worth repairing thanks
    Scholar:
  • 168 Answers
It looks like u have a problem in color circuits worst maybe the crt itself.
Posted on Jan 15, 2007
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Sony model KV-32FS120 bad picture green and red colors
I can't tell from the description but it sounds like the Degausser in the set stopped part way.-----does the purity change if with set on you turn the set itself?
Dec 22, 2012 | Televison & Video
My RCA 54 in projection tv shows a blurred picture
On the RCA - Color Wheel Encompass Parts Distr look up online or call them 1-800-638-3328 Other TV could have Bad capacitors pull back off if any of the caps are puffed up on top then they are Bad 1000uf 16v , usally find 2 or 3 bad
Oct 08, 2009 | RCA HD50LPW175 50" HDTV
I have a 20yr old cs-3505r picture tube just went out .
If the picture tube is bad (no likely), then the set is not worth repair. If you have no picture, it could be as simple as a bad horizontal Output Transistor or other simple component. In that case it would be relatively cheap to repair. If the picture was good before it stopped, perhaps it is worth the estimate charge at a local shop to find out the problem. Unless it is an obscure failure, the parts to repair it should be available generically and inexpensively. Keep us posted. Dan
Jun 12, 2009 | Mitsubishi CS-35305 TV
Sony KP-53V75 picture problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 12, 2009 | Sony KP-53V75 53" Rear Projection...
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Sony Trinitron KV-32XBR37
This may be a bad crt or picture tube. Take a good look at the picture when it's on and see if it has a pinkish or greenish tint. This is easiest to see if you turn the color adjustment all the way down. If it looks like the tint is green or pink and the focus isn't great then it's probably a bad crt. Not worth repairing if its the tube.
Jan 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV REPAIR
John, bad news, short in picture tube, not cost effective to repair, even if it was the tube is no longer available for that age set, the bright side is it doesn`t owe you anything at 15-16 years old, too bad the "new tv`s" don`t last that long, hope this answers your question, BMW Rider
Dec 07, 2007 | Televison & Video
No Green in picture
KV-32S... and KV-32V.... notorious bad picture tube.....
not worth pursueing..........................T.
Sep 04, 2007 | Sony KV-32S20 32" TV
Sony KV-27V42 27" TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
