Question about Garmin Nuvi 660 GPS Receiver
Auto shut down screen does appear when ignition is turned off
Unit stays on continuosly when car is shut down, the auto off screen never appears asking to shut unit off/leave it on. If I take unit out of it's cradle the auto off screen comes on. It's plugged into the lighter circuit?
  • navymmcpo Nov 29, 2008
    Thanks, kinda figured that I was still getting the 12 VDC. I'll have to put a meter to the receptacle and figure it out, dam thing keeps draining battery if I forget to turn it off.
  • Anonymous Feb 12, 2009
    I have a same problem with my garmin does not shut down when i turn down the car but my car outlet working fine an it's ma cigarete lihter is off when i turn off key of my car. thx for solutions
    Brain007
  • Garmin Master
  • 2,124 Answers
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Posted on Nov 28, 2008
Ine-w927hd gps auto detecting problem
Unit: Alpine INEW927HD
ISSUE: GPS not working - spinning to connect
Symptom: GPS goes into an Off State
Screen states - Auto Detecting GPS Receiver - This went on for days.
My Fix to the issue: Hold down the reset button on the front of the unit for 15 seconds.
After the unit restarted GPS and Maps worked just fine.
Feb 23, 2013 | Alpine INE-W927HD - 7" In-Dash Navigation...
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found .... http://www.retrevo.com/pdf/23127ci168/76/Calibrating+the+Screen#q=Garmin+285WT
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
I have a garmin gpsmap 498, 4 yrs old. I have been loosing satellite reception. I have examined the coax cable- I do not see any issues. Where do I look?
Had same problem,,, you need to perform an "Auto-Locate" With unit plugged in but not turned on, push the Page and Power buttoms at the same time,,, continue to hold down the buttons until the "I Agree" message appears. Then release the buttons, agree by pushing Enter. The system will then go through an Auto Locate sequence that corrected my problem.
Sep 10, 2009 | Garmin GPSMAP 498C Sounder GPS Receiver
Turn off the TomTom One auto zoom feature?
Turn on tt. tap screen, tap preferences, go to automatic zooming and disable it.
Hope this answers your question.
May 03, 2009 | Tomtom ONE GPS Receiver
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Touch screen does not work.
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
707 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
