Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Problem for Canon Digital Rebel / EOS-300D Digital Camera with EF-S...
Hi, my canon 300d gives
By devonlg7 on Nov 28, 2008
Hi, my canon 300d gives error 99 and doesw not work
Solution #1
posted on Aug 27, 2009
Not Rated)
lundfamily5
Rank: Wiz
Rating: 85%, 24 votes
err 99 is moisture or dew inside the camera.
Was this helpful?
Yes
No
Solution #2
posted on May 14, 2009
Not Rated)
smartr10U
Rank: Guru  Canon Expert
Rating: 87%, 521 votes
Error 99: tthe lens contacts are dirty- get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Comments:
May 14, 2009
- the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Was this helpful?
Yes
No
Solution #3
posted on Mar 23, 2009
Not Rated)
JohnLeF
Rating: 90%, 101 votes
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
Popular Solutions for Canon Digital Rebel / EOS-300D
Questions and Unsolved Problems for Canon Digital Rebel / EOS-300D
Do you recommend Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens?
Answer
Answer
I am trying to replace date-tie battery in Digital Rebel 330D. I can't find hoie to get the old... (More)
Answer
Our Canon 300D lens (35x105EF) will not focus in automatic mode.
Answer
my daugher was taking pictures with my canon digital camera rebel, EOS 300D taking picture and... (More)
Answer
Looking for the name of the part behind the mirror but over the ccd that folds away just prior to... (More)
Answer
My Canon EOS Digital Rebel LCD Screen just shows an all-white display instead of picture preview. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon Digital Rebel / EOS-300D...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
