Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Fridge leaking oil on the bottom right side
I have a Frigidaire GLRS237ZA that is around 4 yrs old and I notice a strange noise when I would get ice then a couple of days later I notice that an oily sticky black substance was leaking out the bottom of the fridge. It was on the right side of the fridge close to the front. At first I thought it was syrup spilling from inside the refrigerator because it was sticky and it had the same color as syrup. But I notice that the syrup was not leaking so I cleaned it up and left to the store. When I got back I notice that everything in the fridge was melting so I cleaned out the refrigerator and check to see if the compressor was running, everything seemed fine and I notice after a couple of hours everything was cold again. Then the next day I notice that it was leaking again in the same place. So far the refrigerator seems to be working fine, everything is still cold I am just concerned that there may be something wrong with the compressor. Can someone please help? Thanks, Mike
  • 1 more comment
  • Anonymous Feb 06, 2008
    Refrigerator leaking oily substance from the bottom.
  • Marcus Z Sep 21, 2008
    Product: Amana ABB1927DE (Bottom Freezer).
    This product is two years old and the fridge has a plastic tray in the back bottom of unit below the compressor and fan. I assume this is to catch any potential leaking compressor or sealed system oil. The tray contained some dark syrupy oil that smelled very bad. I could not find a way to easily remove the tray so I wicked the substance up with absorbant tissue. The next day the tray contained 1/8 inch more tan liquid and again I am wicking this up. No other fridge symptoms are present yet. What is going on with this relatively new refridgerator?
  • Anonymous Mar 26, 2014
    my fridge isabouttwelve years old has been working ok. yesterday I noticed it wasn't staying cold the inside light is on but its not making a noise to let you know it is running I have turned it off for a few hours and cleaned it then turned it on again but nothing
  • 237 Answers
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Posted on Jan 15, 2007
I have a westinghouse cyclic defrost fridge and at the bottom left hand side of the cooling plate is a cover which is now accumulating ice which is not defrosting properly, it just stays there all hard and can't be removed. When it goes through the defrost cycle, this ice defrosts a little causing it to leak in the fridge. What is causing this hard block of ice?
Posted on Jan 27, 2007
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
ICE MAKER NOT MAKING ICE AND LEAKING
Your ICE MAKER may be blocked in some way [CLEAN water inlet lines &/or replace the in-line FILTER] OR the THERMOSTAT could be faulty [in an older unit]. Check all in-line water pipe connections for leaks AND/OR damage from any rodents you may have had in your home. This is particularly prevalent in tropical areas and when inlet lines are made from any type of nylon/plastic material. ALSO check your DOOR SEALS as this will sometimes cause this type of problem. It is also possible that the INSULATION in your older unit may be breaking down [you will notice moisture/"sweating" on the outer case surfaces which would indicate this type of fault].
Sep 21, 2014 | Frigidaire Refrigerators
My side-by-side Frigidaire is 3 yrs. old. Yesterday it started leaking water around the outside of the ice/water dispenser. No leaking on the inside. can the front panel be removed? what would make it...
Hi, look for a small aperture inside compartment. thin stiff copper wire and clear blockage. Being firm yet gentle, you could damage tubing!
This hole is the defrost exit which usually exits into a tray were the heat of the motor evaporates the defrosted ice.
May 12, 2011 | Frigidaire Refrigerators
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water line vibrates and makes noise when using it. It sounds like there's air in the line.
Does it make noises when anything else in the house uses water?(sinks, toilets filling up?)
If not the pull the fridge out and make sure water line clamp was installed. It will be a small clamp near the bottom of the fridge on tha same side the line comes into the back of it.
Is there a water filter that has been replaced recently?
Aug 30, 2008 | Frigidaire GLRS237ZA Side by Side...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Ice build up on fan
problem is most likely caused by water overflowing from ice tray and then freezing to motor, hold light switch in and see what happens when tray fills up. Regards Advisor
Feb 08, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
9,710 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
