Question about Dell Inspiron 1501 Notebook
Computer is sticking and slow
My computer is slow starting up and seems there's a block.
    Problem Solver:
  • 18 Answers
HI
All you need to do is to run an Anti-Spyware program on it. Normally it will make it go faster.
Also you might want to try to limit startup programs meaning to get the laptop to start the minimum programs possible.
You might want also to backup your personal files and scrap everything, do a fresh installation.
Hope it works fine
cheers
Posted on Nov 28, 2008
Have to put hand over mouth of carb. to start
Hi, Ronnie and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
Good luck and have a nice day.
Feb 28, 2016 | Motorcycles
Yamaha Zuma 50/Cold Start Problem
Hi, James and the usual suspects are:
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic 2005 yamaha zuma yw50t cold start issues
My Scooter wont start if engine is cold scooters
https://www.manualslib.com/manual/781192/Yamaha-Cw50l.html#product
OEM parts for Yamaha
Yamaha ZUMA CW50N Owner Manual
Jan 22, 2014 | 2012 Yamaha Zuma 50F
Strating PROBLEM
Hi, Andrew and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
Sym Jet 50 Service Manual
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
I have a Precision 670 that I put two 512MB DDR CL3 ECC REG ram sticks in and it will start up but when it reboots, it beeps two slow, two fast, two slow and stops. lights on front turn: AC are...
The issue seems to be that your PC can not handle the supported memory. After review of your system specs on dell's website, I see that you're computer would require DDR2 Memory. This seems to be what is causing the beeping. Please check to ensure you are using the correct memory stick. I hope this has helped
Jul 05, 2011 | Dell Precision Workstation 670 PC Desktop
After priming engine starts first pull, runs a few seconds, occasionally a minute, then slows down and stops like it's out of gas. Will start again on first pull only after re-priming and then runs a...
Hi well this is a little odd,however i have come across a similar thing like this before and what fixed it was the tank breather, it was blocked and after a while the tank developed a vacuum and gas wouldn't flow, so i wonder if this is the same or similar worth a try anyway? try loosening the top a little and see? If that works check the breather tube?
Otherwise, i think that it still must be a gas problem and would troubleshoot that area? maybe the float sticks?
Jun 24, 2011 | Garden
WHEN USING YOU TUBE THE VIDEOS SEEM TO STICK AND THEN START AGAIN and then stick again and start up again ....why? 4 GB RAM and processor i7 using but video seem very slow
Sounds like It's your internet connection if your on wireless make sure your connected to your network or a strong connection.
best of luck
Mar 04, 2011 | YouTube Videos
When it is powered on it goes in super duper slow motion to open windows and then to load everything almost not starting or loading . it takes hours to get to have computer loaded.
Check out the tips and tricks on this site. Several of us have written tips concerning how to speed up your computer.
The tip I wrote is:
Why is my computer so slow and how do I fix it?
Jan 14, 2010 | Compaq Presario 700 470024-192 Notebook
VW touareg steering judder low speed left/right turn
Sounds like you have air in your steering system. I would start by looking for any leaks on your steering system like hose to fitting crimps, steering pump, etc. Check your steering fluid level to make sure it is full and also look for bubbles on the dip stick. If everything looks good, start the vehicle and turn the wheels all of the way to the left and then to the right. Do this while the vehicle is in park and repeat at least 5 times. This will work out any air in your steering system. If the problem persists then the power steering pump may need to be replaced.
May 24, 2009 | 2004 Volkswagen Touareg
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
Dell Inspiron 1501 Notebook Logo
63 people viewed this question
Alun Cox
