Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
I have a large horizontal black line in the middle of the screen.
The line comes and goes and sometimes a 2nd line is there at the bottom of the screen. It is connected to cable and we had the cable guy in and he said it is not due to their equipment. Also sometimes if you turn the main power button off when you try to turn the TV on again you get a blue screen. You then have to play with the power button turning it on and off until it finally comes in with wavy lines...after a while a clearer picture comes in and then the black line comes back. The black line sometimes disappears and then reappears. Seems like light colored backgrounds make it appear more often as do cartoons.
  • Anonymous Dec 21, 2008
    ya i get the same problem on my new LCD Sony Bravia 4
5 Suggested Answers
SOURCE: APEX TV problems
need flyback transformer #030531-5283
Posted on Sep 24, 2007
  • 7 Answers
SOURCE: 51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Posted on Apr 15, 2008
  • 90 Answers
SOURCE: Hello, I have an Apex GB5108 and it has a
I am not familiar with this particular set, but it sounds like you have no vertical deflection, which would mean your vertical output IC may be bad. The # on those ICs usually start with LA and is mounted to a heatsink.
Posted on Jul 30, 2009
  • 135 Answers
SOURCE: Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Posted on Mar 04, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
Our Toshiba Regza LCD TV has developed a thin white vertical line down one side and a green horizontal line across the middle. The bottom half of the TV screen then comes and goes in muted and faded...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Aug 06, 2011 | Televison & Video
Black Horizontal Line in Screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jun 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
35 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
