Question about Whirlpool GH7145XF Microwave Oven
Microwave does not heat
All electronics, display pannel, clock, light, work but the turn table and heating both quit working at the same time.
  • Anonymous Mar 23, 2014
    Light, clock, turn style,and fan still working
  • Whirlpool Master
  • 5,568 Answers
The high voltage circuit that supplies power to the magnetron may be separately fused inside. Unplug it, remove the back panel and look for a fuse clip. The high current fuses (20-30 amps) often have a white ceramic housing and are tubular. If you have a multimeter at home (you should, they are cheap) you can check the fuse after removing it from the holder.
The reason your other things are still working is that they have separate supplies; the one for the panel will supply only low voltages and not much current.
If you have a meter, check for a largish black plastic component often mounted on the floor of the case. This will be a diode or diode bridge and this can also fail.  A meter would let you check it if you have one.
Posted on Nov 28, 2008
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
I select High/Med/Low, set time say 1 - 2 mins microwave starts up light comes on, fan comes on, table turns...but after 20-30secs table stops, light goes off, disply reverts to clock time, fan runs for...
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type. In this case it seems that the program controller board has errors specially if the oven heats and shuts off. remove the board, clean and reset.
If there is heating without any issues, you can use the microwave safely
May 16, 2011 | Microwave Ovens
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
95 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
