Question about Weather King Heating & Cooling
Blower motor My blower motor doesn't run when the heater is on. I was told it might be a relay but im not sure which one it might be i could use a schematic on the wiring.
  • 1 more comment
  • steelsmith1 Nov 28, 2008
    The blower does not run at all even set in the on position
    I found the relay that runs the blower motor. the motor tries to come on but does not turn. I taped on the relay that leads to the motor and the motor started running. So im going to try and find the relay today and see if it works.
  • Ken Bledsoe May 11, 2010
    Does the fan run if you switch the themostat fan setting to run from auto?
    Problem Solver:
  • 25 Answers
Follow the wires back from the motor to either the relay or the circuit board. normally a furnace has a board. check to see if there is any power leaving relay/board to the mtr. if it is a furnace you may need to push in the door saftey switch to get power to system. heat pump mtrs need 230 vlts furnaces 115vlts. If the power is going through to mtr properly than problem is either capacitor or mtr. capacitor can be checked for you by a local hvac supplier or buy a meter that can check it.
PLEASE rate or solution thanks. Brian S.
Posted on Nov 28, 2008
  • cotillionsor Nov 28, 2008
    if you do as i suggested it will let you know the problem it takes my about 30 seconds to trouble shoot this problem when i show up.
  • cotillionsor Nov 30, 2008
    you can bypass the relay for now. if you take the wire sending high voltage to the relay and the one to the moter cut off the spade connectors(buy some to replace these and wire nut them together the blower should run constantly which will let your heater cycle on and off till you get the relay. make sure to turn the power off! first please!
WHERE on a 1990 FORD TEMPO location is the RELAY that controls the switch to the heater blower ???
Dec 16, 2015 | 1990 Ford Tempo
2005 dodge durango front heater/ac blower motor doesn't work
Check fuses and relays. On relay just switch with one you no works.
Feb 20, 2013 | 2003 Dodge Durango
1998 buick century my heater and ac fan only work on high i'm told it's the blower relays where are they located
they are not relays its a blower motor resistor a one piece unit usually held in by two bolts and an electrical connector either under the passenger side dash or behind glove box
Aug 03, 2012 | 1990 Buick Century
1991 Olds 98 Elite heater blower motor continues to run with key off. Will change speeds with controls but will NOT shut off..
if you haven't got your blower fan fixed yet, im sure it to be the same as mine, the blower motor relay which is out on the firewall under the big fuse block. take plastic cover off over the fuses and move the fuse block out of the way and you will see it staight under that. should be two screws holding it on.
Mar 05, 2010 | 1991 Oldsmobile Ninety Eight Regency
Heater blower moter runs off and on
look in your owners manal it mite tell you witch one it is
Feb 23, 2009 | 1992 Buick Park Avenue
Heater motor fan
when it wont work leave the truck on and open the hood on the passager side the blower motor is there gently tap it if its start change the blower motor that the fast way to do it im sure its our motor good luck pierre p.s dont forget to rate me after you tryed what i told you
Jan 09, 2009 | 2000 GMC Safari
Heater/ac only works on high...and on high it's extreamly noisy
sounds like relay to me but what blew it, most likely dry bearings on blower motor causing your noise clean oil fan motor install relay
Dec 27, 2008 | 1996 Chevrolet K1500
Heater blower motor wiring diagram
replace the bolwer motor relay mounted on the fire wall the relay is stuck in the on poition.
Dec 07, 2008 | 1996 Oldsmobile Aurora
Blower for AC/Heater stopped working
if you can reach the blower motor, it could be a worn out carbon brush of the blower motor. if they are, buy a set of carbon brush, learn how to replace them and it would be back running in no time. by the way, when you pull out the carbon brush holder, make sure you dont interchange the position. you can put them back wards and what would happen is the rotation will be reversed. either you reversed the carbon brush holder or just simply interchange the wires that are coming to the motor. i hope i was able to help...
Jul 07, 2008 | 2000 Ford Focus
Heating & Cooling Logo
133 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
