Question about Hitachi 53SWX10B 53" Rear Projection Television
Shadows on left side of screen,right side has no shadows
I have a 53 SDX01B Hitachi Projection Color TV My Picture is good except the shadows on the left halve of the screen.The TV has been moved from the other side of town on a trailer. Thank you.
Gerhard Froehlich
  • Hitachi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the bShadows on left side of screen,right side has no s - 69189a5.pngt fails to fix the convergence your need to fix it. See below for a fix
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. ...
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
53 Hitachi Rear Projection TV with shadows and double images
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color shadows
Good Day, beekae;
No, there no other adjustments that can be made, the TV has had a Convergence Circuit Failure. The "CCF" is caused by that circuit, please call an Authorized Service Center and get an estimate. The avg cost is about $550.00. Good Luck, big IRISH.
PS or come back and I'll tell how to fix, if you are handy and own a good soldering station.
Aug 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green shadows all over the screen
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Apr 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
is this a color shadow like convergence problems or just dark?
Dec 26, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 53SWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
