Question about Uniden GMR-1558 / 2CK 2-Way Radio
I have uniden gmr1448-2ck and both radios on same channel however not able to communicate between them. help please???
  • restorations Jan 14, 2009
    I have tried everything and cant get mine to talk to each other either.
2 Suggested Answers
  • 24 Answers
SOURCE: Uniden GMR1448-2CK
sounds like you have one units side channels set diffrent than the other.you should be able to reset this by reverseing the battries in both units for a few moments then replacing them correctly. or remove battries for 24 hours or more to delete memory
Posted on Dec 13, 2007
Re Uh8060S new unit cannot move off channel 80 nothing in manual explains. Can you help?
The manual tells you how to preset the Channel when you turn it on if you don't want channel 80. The normal is 16. It tells you how to scan channels and it tells you how to step up and down through the channels. Read from Page 3 with the unit in your lap.
Uniden UH8060S 80 Channel UHF CB Radio with Masterscan ' JB Hi-Fi
https://www.jbhifi.com.au/phones/UHF/uniden/uniden-uh8060s-80.../702883/
May 4, 2017 - The UH8060S is extremely compact, yet so versatile and full of features and is now equipped with Masterscan™ Technology. The UH8060S is ...
UH8060S - Uniden Australia
https://www.uniden.com.au/Australia/default_print.asp?product=p_uh8060s.htm Introducing the latest in UHF communication from the world leaders in wireless communication. The UH8060S is extremely compact, yet so versatile and full of ...
[PDF]UH8060S - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060S_Brochure.pdf UH8060S. MOBILE. UHF CB. 18+ km# for AUSTRALIAN and. NEW ZEALAND conditions. BUILT. RUGGED. Master Scan. ™. 7 Colour LCD. Key Backlight.
UNIDEN UH8060S OWNER'S MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Uniden Manuals > Transceiver > UH8060S View and Download Uniden UH8060S owner's manual online. Uniden UH8060S Remote Speaker MIC UHF CB Transceiver. UH8060S Transceiver pdf manual ...
Uniden UH8060S Owner Manual Page 3
Sep 01, 2017 | Televison & Video
I cant Communicate with my Motorola T5000. Talkabout and Uniden PMR 1188.Is there a way to do it?Please help.
To answer yr question is very simple..
the radios you have are not able to operate in Australia as these units work on a frequency range (462MHz-464MHz), which in the USA are allocatted as license free. In Australia, you need a license to operate in this frequency band, as a commercial or government user. Sorry but, PRM/GMR radios are blocked in Australia.
Peter
Mar 03, 2013 | Uniden GMR100 (8 Channels) 2-Way Radio
I can not receive any channels with my uniden bearcat ubc60xlt.i have heard that police,etc have went to tetra?unsure how to receive these.please help.
TETRA is a relatively new trunked radio system that is coming into wide use in Europe. It uses digital technology unlike "standard" trunked systems, and there are no scanners available that allow monitoring of TETRA systems. For more information on this technology, there's a pretty good article you can read here: http://www.radio-electronics.com/info/cellulartelecomms/private-mobile-radio/tetra/what-is-tetra-radios-communications.php
Bill B.
Listening in since the 60's
Jan 21, 2011 | Uniden BC60XLT-1 Handheld Scanner
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Only one unit of my Uniden walkie talkie model no 1038-2 works
Check programming. Channel and selective call must be the same on both radios. Check "mic" opening hole on the front case of the radio. The slightest bit of debris blocking this tiny hole can reduce transmitted audio to zero.
Jul 26, 2017 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Replacement parts
Hello daemon10,
The current trend is for manufacturers to bundle consumer two-way radios in packs of two and four since most users do not purchase single radios. However, some models are available as single units and any 22 channel FRS/GMRS combo radio should be able to communicate with your Uniden radio.
If you definitely want to get the exact same model you might have to either purchase another two-pack or contact the manufacturer directly to see if they have single units available
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 05, 2008 | Uniden GMR1058-2CK (7 Channels) 2-Way...
They are not working
First,we call this transciever as SRRS (Short Range Radio Service), it can communicate within 500 meters open range or no obstruction,now if the unit can't communicate each other within the range ,i would suggest to sent it to uniden service center......
Feb 24, 2008 | Uniden GMR1588-2CK (2 Pack) (7 Channels)...
Uniden GMR1448-2CK
Dec 09, 2007 | Uniden GMR638-2CK (22 Channels) 2-Way...
Uniden GMR-1558 / 2CK 2-Way Radio Logo
41 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
